Paging WCH- Mtbr.com
Results 1 to 3 of 3
Thread: Paging WCH
    Authority is dead!
    Reputation: Lucky13's Avatar
    Paging WCH
    Hey, I remember you were saying that in order to run front hydro line thru the headlock, you made a u shaped cut in the top cap. Question: how far in did you have to dremel? It looks like mine has to be drilled all the way to the bolt, but I'm afraid to do that and wanted to get your opinion before I do that.
    Thanks in advance!
    For the love of Oi
    Rent a house at Attitash
    Pro Crastinator
    Reputation: .WestCoastHucker.'s Avatar
    first, feed the hose thru the steerer. then make a small groove in the edge (mine was only about 1/4", just slightly bigger than the hose) then fit the topcap into place. don't try to put the topcap on first and then feed the fitted end of the hose thru. your final groove should be no where near half the distance across the cap....
    Authority is dead!
    Thanks! I just got Shimano SS line which is a bit thiker than normal Hayes like I guess. Will try it tomorrow.
    For the love of Oi
  1. paging WCH and Zedro
    By SHIVER ME TIMBERS in forum Downhill - Freeride
    Last Post: 02-16-2005, 09:32 PM
  2. Paging Shiver and WCH
    By FatTireMike in forum Downhill - Freeride
    Last Post: 01-22-2005, 10:28 PM
  3. Paging WCH
    Last Post: 09-15-2004, 12:05 PM
  4. Paging WCH
    Last Post: 09-08-2004, 03:44 PM
  5. Falls City with WCH ... and others
    By pdirt in forum Downhill - Freeride
    Last Post: 08-04-2004, 10:50 AM
