P2 Bottom Bracket- Mtbr.com
Results 1 to 5 of 5
    Sep 2004
    P2 Bottom Bracket
    I thought the P2 had an ISIS bottom bracket, but those arent supposed to creak and my cranks do. Anybody know what kind of bottom bracket comes stock on the '04 P2???
    Quote Originally Posted by surfdude660
    probably just got some grit in there. Pull it apart, clean everything, regrease everything, put it back together
    Disco-Superfly
    Reputation: Jake_HT's Avatar
    the BB on the p.2 is a : Truvativ.... it does not have a model name, I have it it my hand right now..... BEACUSE IT BROKE ON ME!... it says on it: ISIS DRIVE DH...
    but it didnt handle DH very well. I have had cracking(noise) problems with mine too, i just took it off and greased it. its broken now, so there was only one thing to do.
    Buy the Gigapipe Team DH.
    I have the '04 p.2 case you wanted to know.
    Jake
    Yeti 303 WC 25th
    Quote Originally Posted by Dwight Moody
    Didn't you read the sticker on that shock? It said not to do whatever you did.
    style, flow...RIDE!!
    Its ISIS...
    its a truvativ ISIS DH bottom bracket, I got and P.2 too . mines doing the same thing, its just dirt that has to be cleaned out..
    Scratchy Rat Racing
    "It's not that I'm lazy, it's that I just don't care."--Office Space
    When in doubt, whip it out. -Gee Atherton.
    Don't skid
    Reputation: KONA_in_SB's Avatar
    Ya, its ISIS, but it does get dirty. Did you ride through any water lately? That will make it creak. Buy a crank arm puller and a bottom bracket puller ( togethr should be less than $30 and your LBS should hook you up with the right size), pull that b!tch apart, clean it, and lube it like you would your johnson after your little sister's ballet recital, you sick MoFo, j/k.
  1. bottom bracket type??
    By Styles in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-06-2004, 10:06 AM
  2. @#$%^&* Shimano bottom bracket mounted derailler
    By old_dude in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-02-2004, 10:04 AM
  3. Replies: 10
    Last Post: 05-24-2004, 12:06 PM
  4. Please help! Broken bottom bracket lock ring.
    By Bart in forum General Discussion
    Last Post: 05-15-2004, 01:09 PM
  5. Help with bottom bracket
    By DoothaBartman in forum General Discussion
    Last Post: 04-10-2004, 02:44 PM
