p.2 2nd chain ring compatible?- Mtbr.com
Results 1 to 5 of 5
    is it possible to put a second chainring on the p.2? and wat do u guys think of putting the boxxer ride on the p.2 for freeriding
    Disco-Superfly
    Reputation: Jake_HT's Avatar
    Quote Originally Posted by krazykxrider
    Yeah, I think you can put on a second chainring, doesent the 03 have one?
    I had a tall dual crown on my p.2, and i will tell you this:
    Its the best. Looks sexy and it so easy to work with .
    Does that answer your questions?
    Jake
    Yeti 303 WC 25th
    Quote Originally Posted by Dwight Moody
    Didn't you read the sticker on that shock? It said not to do whatever you did.
    sounds good, wat would i have to buy for it to have 2 chainrings. i know a deraluir and a new chain ring but will the cranks and stuff fit? and will i have to take of the chain teinsor thingy
    Getting back into it...
    Reputation: ryanc44's Avatar
    Not knowing the setup you have on there right now, you'll probably need this:
    -Front derailleur
    -Granny gear chainring- assuming you have a 32 or something right now and you want the granny to do some climbing? If your P2 is still off-the-rack stock, most likely you have a 36 or 38 on there, so you can run a 22/36, but 22/38 might cause you some derailleur issues, so you might need to buy 2 new rings. Or go with a 24 or 26 granny and you're ok.
    -New chain- I like a new chain (depending on how beat your old chain is) when I get new rings, but that's just me.
    -New chainguide- your single ring chainguide isn't gonna work with a dual ring setup. Your bashring (assuming you have one) will be fine, but yes you will need a new roller setup to accomodate the two rings. Don't know if MRP or e-thirteen sell just the roller to move to a LRP or DRS (respective dual ring setups offered by those guys)- most likely they don't...
    Let me know how it turns out. I have a 3-ring setup on my freeride bike and I'm looking into moving down to a 2-ring, so I've been doing some research...
    the 03 comes stock with a dual ring set up
  1. Took a rock on my big chain ring!
    By Ronnie in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-19-2004, 06:54 AM
  2. chain binds up on smallest crank ring
    By ewarnerusa in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-10-2004, 09:23 PM
  3. When is a chain ring done?
    By aka brad in forum Singlespeed
    Last Post: 06-26-2004, 05:54 AM
  4. chain ring & crankset question
    By chickenlegs in forum Singlespeed
    Last Post: 04-26-2004, 06:12 AM
  5. Need a new mid chain ring. Which one?
    By DudeOnABike in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-30-2004, 12:13 AM
