Online dealer for Fox Shox parts- Mtbr.com
Results 1 to 3 of 3
    Reputation: buccilli15's Avatar
    Hi all,
    I haven't contact Fox Shox directly, yet, but I'm looking for an online dealer that carries spare parts for the Vanilla rear shock. Specifically, I'm looking for a replacment preload adjuster ring (threaded ring that compresses/extends the spring)...
    To make a long story short, last night I went to adjust the sag and the LBS had the ring compressed so friggen tight (I haven't ridden the bike since the LBS worked on it 2 weekends ago..) I had no choice but to break out the channel locks, the ring is still functional, just looks like crap.
    On a side note, what's an approximate proper adjustment before changing springs? One turn after the ring touches the spring?
    Err
    Err is offline
    Calm like a bomb
    Reputation: Err's Avatar
    Mar 2005
    Prob best to call Fox directly
    Two full turns is about the maximum pre-load to use. The less the better. Be wary of any shop that would tighten down your pre-load adj so tight that you wouldn't be able to turn it by hand.
    RTM
    RTM is offline
    #1 Latex Salesman
    Reputation: RTM's Avatar
    if memory serves they recommend no more than 2 full turns after the ring engages the spring. I think your best bet is to go through fox direct, or as your LBS to order the parts for you. I've been searching for a new spring and can't find one anywhere.
