Norco Team DH shock mounting hardware sizes?
Hi,
Hoping someone might know these numbers. I'm thinking of buying a CCDB shock for my 2010 Norco Team DH. They don't know the mounting hardware size that I need. I tried getting in touch with Norco, but they don't provide any contact info, email or phone, and when a local shop called them to ask they said "It's all standard and you should be able to reuse old hardware", which according to Cane Creek is NOT true. So I'm wondering if anyone knows the bolt diameter and spacing between the eyelets on frame (width of reducer cups). I'll try measure myself if I find some calipers, but I can't get an accurate enough reading with my tape measure to feel good about ordering the parts.
Here's what I measured off my frame.
Front Mount.: 24mm
Rear Mount.: 42mm
When your dealer called they probably didn't specify which shock the mounting hardware was going on. That or they were dealing with a newbie.
According to Fanatyk Co in Whistler it's:
EDITED to reflect my measurements:
24mm x 8mm (reducer width x bolt diameter)
42mm x 8mm
I'm gonna try get calipers and measure at home to confirm. The shop told Norco it was for a CCDB. They must've gotten a newbie because Gary at Cane Creek confirmed that Fox hardware won't work.
Thanks for checking your bike.
Must have, since they're a Cane Creek distributor.
The measurements I took we're with taken with a very good caliper. I checked both the hardware and the mounts at the frame.
Thanks man. Appreciate you measuring for me, especially since Fanatyk Co didn't give the correct numbers. I borrowed calipers and measured my frame and also confirmed that it's 8mm bolts and 24, 42mm wide mounts. I edited the other post to reflect these numbers.
By broncbuster in forum Shocks and Suspension
Last Post: 01-05-2010, 03:29 PM
Last Post: 06-19-2009, 02:56 PM
By the_one in forum Norco
Last Post: 12-31-2007, 05:11 AM
By schoolisbad1 in forum Shocks and Suspension
Last Post: 10-16-2006, 03:38 PM
By jbeerm in forum Shocks and Suspension
Last Post: 07-10-2006, 05:09 PM
- You may not post replies
- You may not edit your posts
Forum Rules
