norco six how heavy????- Mtbr.com
Results 1 to 7 of 7
    Feb 2005
    hi
    anyone know how heavy a norco six frame weights?
    or a complete bike
    I want to build one as a allround bike but I am not sure if it will be too heavy to ride up steep hills, what do you guys think????
    There's no app for this.
    Reputation: JimC.'s Avatar
    41.5 pounds
    it's on Norco's website.
    Jim
    FRAME: Hydraform aluminum, 5.5" to 6.5" adj travel, 150x12 dropouts, CNC yoke, FOX DHX-3 7.857x2" coil shock FORK: Marzocchi Z-1 FR2 150 mm travel, QR-20. preload / rebound adj
    HEADSET: FSA 870 Chromoly deep cup freeride headset CRANKS/CHAINGUIDE: Truvativ Hussefelt, dual 32/22 with bashguard, Isis spline
    PEDALS Wellgo flat pedals with steel insert pins CHAIN: Sram PC-950 chain
    FREEWHEEL: Sram PG-950 cassette 9sp, 11-34T FRONT CHANGER: Shimano Deore 31.8
    REAR CHANGER: Sram X9 9-SP long cage SHIFTERS: Sram X9 Trigger Shifter front and rear
    BAR: Truvativ Hussefelt 31.8 mm, 35 MM rise AL-66 STEM: Truvativ Hussefelt 40 mm ext, AL-6066
    GRIPS: ODI Ruffian 130 mm lock on grips FRONT BRAKE: Hayes HFX-9 hydraulic 8"
    REAR BRAKE: Hayes HFX-9 hydraulic 8" BRAKE LEVERS: Hayes HFX-9 levers
    FRONT HUB: KDH5 20 mm through axle, IS disc mount REAR HUB: KDRN512 150 x 12 mm nutted, 8-9 sp cassette sealed bearing
    RIMS: Alex Supra N 26", 32H freeride double wall SPOKES: DT Swiss 2.0 Black stainless
    TIRES: Nokian NBT 26 x 2.30 Front and rear SADDLE: Titec Berzerkr comfort freeride saddle
    SEATPOST: Titec Scoper telescopic seatpost 30.0 COLOURS: Dark Matte
    WEIGHT: 41.5 lb
    Feb 2005
    i can't see much way to get a few pounds off that except forks or tyres
    the frames are 550 ($1050) which as cheap as FS comes in the UK, we get screwed big time for bike parts even by UK companies :- orange bikes
    even a yeti as-x weights less than that, would that make a better all round bike?
    I don't know Yeti
    they just came to Canada and I don't know anything about them. I can say the Heckler makes an excellent all-around bike...you can build it burly and DH/FR it, or build it up for XC and keep it under 30lb easily. I believe the Yeti is similar.
    I don't know how you want to use it so I'm guessing here.
    Jim
    Tear it all out! SuperModerator
    Reputation: CraigH's Avatar
    Recent review of Norco Six on NSMB's site.
    http://www.nsmb.com/gear/gear_shots10_02_05.php
    Glad to Be Alive
    41 pounds lose some weight by going tubeless
    My large 04 was 43 pounds stock. Quite tiring to climb steep hills in stock form, but it'll get you there. With some judicious parts-swapping, you can drop quite a bit of weight. Mine's 37 pounds now and still bomber. Once your legs adjust to it, you can climb anything that you could on a light bike. Here's what I changed and approx. weight savings:
    Tires and tubes - switch to Kenda Nevegal 2.35 folding and normal tubes - 3 lbs
    Fork - switch to Mantiou Sherman Firefly - 1.5 lbs
    Cranks - switch to new-style XT - 1 lb
    Seatpost - switch to Thomson 27.2 with QBP reducer - 0.5 lb
  1. Prophet, Chaparall, Norco 6? (x-post)
    By Techfreak in forum Downhill - Freeride
    Last Post: 02-18-2005, 03:20 PM
  2. norco six 04
    By anti-spandex in forum Downhill - Freeride
    Last Post: 09-21-2004, 05:53 PM
  3. how heavy is the norco atomik?
    By LoozinSkin in forum Downhill - Freeride
    Last Post: 08-11-2004, 01:20 PM
  4. Giant Rock VS Norco Mountaineer
    By SomeBikerGuy in forum Beginner's Corner
    Last Post: 07-27-2004, 04:17 PM
  5. Why is 30+lbs considered heavy for a "do anything" trailbike?
    By BanzaiRider in forum Bike and Frame discussion
    Last Post: 05-05-2004, 05:09 PM
