The New Specialized Demo, OHHHHHH Raw- Mtbr.com
Results 1 to 20 of 20
    Reputation: Demodude's Avatar
    This is close up pics of the new Demo,
    in the raw........lol Got YA!
    Demo 7 in the raw and some modifications...
    This is the result of about 30$ of paint stripper and superfine sandpaper. I've always hated the color of my 07 Demo 7 and have always wanted to paint it but I didn't have the time to do so.
    I thought I'd give stripping it a shot and I'm very happy. I did a bit of sanding to get out cable rub and rough portions of the bare frame. I went a little crazy and did the brake levers, rims, and shock spring too. I'm going to have to watch the spring for rust I forgot steel could rust,(I didn't think of that b4 I sprayed it), but I have a little bit of lube on there to keep the rust at bay + I live in Socal= the land of little rain. I'm loving the rims, sooo shiny, I looove shiny things,,,,,My Precious!!!
    So,, whaddddya think?
    Ten points if anyone can spot the custom area of the frame......I did a little modding....
    Oh and for you gram counters out there, the front triangle lost about 9 grams, so I think the 100-150 gram weight savings estimates out there are unfounded, I would guess about 25 grams for the whole frame.
    Attached Thumbnails Attached Thumbnails The New Specialized Demo, OHHHHHH Raw-raw-demo-001.jpg
    I'm GNARcissistic
    Looks pretty good. Looks like there were some cable hangers or something on the front tube that you ground off? You should just get that spring re-powder coated in a different color...one that complements the bare aluminum frame. Otherwise, regardless of living in sunny SoCal, it'll eventually rust. While you're at it, get the rear linkage re-anodized as well. The bronze looks a bit out of place. I think they'd both look good in a gunmental grey color...
    Glad to Be Alive
    looks awesome...paint the linkage black too...brown throws it off ....black will bring it all in...frame looks t its
    Ding Ding Ding
    Quote Originally Posted by atchipmunk
    Yeah, cut off the downtube cable guides, now I'm THAT much faster, at least in the wind tunnel the differance is quite noticeable, LQTM (laughing quietly to myself)
    I'm GNARcissistic
    Ancient Chinese Secret
    Reputation: Swell Guy's Avatar
    Jan 2005
    That's cool. Same color scheme as my VP Free, except I went with the black Totem.
    Looks great. It's such a huge improvement on the original paint. I did the same to my yellow Pitch. I painted the rocker black with Tremclad rust paint and am happy with the results. I also made new stickers.
    V-Shaped Rut
    Reputation: big_slacker's Avatar
    Great improvement. The paint job was crap and you did the world a favor.
    meow meow
    Reputation: b-kul's Avatar
    Quote Originally Posted by DWDW
    happy to see someone else rockin eggbeaters on a bigger bike.
    Bike Ninja |||
    Reputation: chooofoojoo's Avatar
    Feb 2007
    Bye Bye lifetime Warranty!
    Proud to represent Mojo Wheels.
    Quote Originally Posted by chooofoojoo
    I'd be hard pressed to break this frame, if I crack a chainstay I'll just buy A new one. Getting a frame in the raw was a option in the past, not sure if it's still is now.
    I'm GNARcissistic
    Quote Originally Posted by Demodude
    I totally agree. The likelihood of breaking these frames is low enough to take the chance. Plus, following manufacturers directions to retain warranty status is too limiting (like having the shop swap pivot bearings). You own the bike, do whatever you want with it.
    It's funny though, there is always a guy who points out the warranty thing whenever there is a thread about making a frame raw.
    I'm liking the looks of that spring, might have to try that out. You think a couple layers of clear coat after will do the job, preventing rust? I have a bottle of paint stripper and clear laying around, very tempting.
    Reputation: kntr's Avatar
    Over the last few years, Ive had to use warranty on two different bikes. I like warranty.
    the test dummy
    Reputation: insanitylevel9's Avatar
    sick!!!!!!!!!!!
    Quote Originally Posted by craftworks750
    Riding a mtb is like a reset button, 10 mins in and there is nothing else in the world that matters.
    my bikes
    Ben
    Quote Originally Posted by jawdrop on hardtail
    I used a zip tie around the coils to scrape the paint off cause it's hard to reach the inside spring areas.
    I'm GNARcissistic
    Quote Originally Posted by kntr
    You might not think so if you had to ride around on an ugly specialized paint job bike
    Seriously though, In 19 years, I've warrantied 1 frame, and that was in the early 90's when weight-weenieism was the mainstream trend. I'm not saying it can't happen, just saying it's unlikely (btw, I weigh 140lbs).
    ^my attempt
    All the stripper did was take off the gloss, I had to use a wire wheel and muscle the paint off.
    looks so much better
    ^my attempt
    I assume it was black before? Looks good. The wire wheel must have been a pain in the ass!
    I posted this In the specialized forums and sombody mentioned chemically removing the brown anodization with oven cleaner or draino. Anyone ever tried this with good results.
    I'm GNARcissistic
    Addicted
    Oven cleaner and a wire brush will take the anodizing off. I've done it to bmx stems and a few sprockets too. I used the Easy Off oven cleaner, sprayed it on, let it sit for 15min, brushed it with a wire/stiff plastic bristle brush, rinsed and be done(may take more than one time).
