New Shiver top crown fo dat ass- Mtbr.com
Results 1 to 3 of 3
    Yo momma's pimp
    Reputation: Nate N's Avatar
    Listen! New Shiver top crown fo dat ass
    Shiver owners, tell me what ya think of these crowns.
    I made them double pinch bolt top and have a triple pinch bottom in the works that will hopefully reduce the twist problem that some are having, as well as the flex problem that I hear complained about so much.
    "So pass me the pipe, and sing me a song, and when the pipe's cashed out just load up the bong"
    Jason Boland and the Stragglers
    I'm playin bocci ball, leave me alone
    Jm.
    Jm. is offline
    Reputation: Jm.'s Avatar
    I'd like more drop than my marzocchi "drop" crown does on my shiver. The clamping area is not quite as much as I'd like. I don't have a problem with "twisting" nor have I directly heard of any, but with super-tall stack-heights like my 1.5 headtube has, it's definitely at the limit of ajustability, and I have virtually no clearence for a tire larger(taller) than I am currently running.
    I know in my heart that Ellsworth bikes are more durable by as much as double. AND they are all lighter...Tony Ellsworth
    One thing that concerns me is that if enough force is exerted on the forks to twist them in the crowns, if you stop that twist, all the force is on the forks tubes. I'd rather straighten the forks out (although it's never happened to me in 2 seasons) than replace a damaged fork tube.
  1. Which Headlock for Shiver DC?
    By flip in forum Downhill - Freeride
    Last Post: 03-23-2005, 11:17 PM
  2. Maverick single crown 125mm fork - 3.5 pounds
    By 2melow in forum Maverick
    Last Post: 02-07-2004, 09:23 PM
  3. Fox Float 100RLC axle to crown distance
    By jennasdad in forum Shocks and Suspension
    Last Post: 01-25-2004, 05:15 PM
  4. '01 Monster drop crown, where???
    By Lucky13 in forum Downhill - Freeride
    Last Post: 01-21-2004, 09:51 AM
  5. Rigid fork for Chameleon
    By SDizzle in forum Singlespeed
    Last Post: 01-16-2004, 09:18 PM
