need new hub dont know which one HELP!!!- Mtbr.com
Results 1 to 27 of 27
    Reputation: MTB_prodigy's Avatar
    I need a new rear hub. My budget is 120. I need 135mm x 36. I really dont know what to get. Im running a grimeca 6 bolt rotor. Any suggestions appreciated.
    Meh.
    Reputation: XSL_WiLL's Avatar
    Gusset, Halo, Atomlab Aircorp (if you can stretch your budget a bit), DMR Revolver, new XT, Formula, Funn, Ringle, Woodman.
    All except for the XT are sealed bearing. All have decent engagement and are decently solid.
    Im a Cowboy
    Reputation: CrustyOne's Avatar
    Oct 2007
    I would think he means 36 hole
    I would go with a Hope pro2, as long as you dont mind VERY loud hubs, its perfect for most uses except perhaps ultra-weight-weenie xc whippet types
    DON'T TELL ME I'M STILL ON THAT FECKIN' ISLAND! ....
    Meh.
    Ahhhh. Yeah, that would make sense.
    Pro II is a bit over the 120 mark though.
    Rb
    Rb is offline
    Feb 2007
    The WTB LaserDisc Lite's not bad... comes in 36 x 135 too
    The new Halo 6-drive looks promising as well.
    Quote Originally Posted by CrustyOne
    I actually wanted a realy loud hub. THANKS!!!
    ill check it out
    and yea i meant 36 hole
    i eat rocks
    Reputation: gil_caz's Avatar
    i have a used hope not sure if its the pro 2 but it is 36 hole. 30 bucks sounds fair as it was not used much and PC white.pm if you are interested.
    Quote Originally Posted by gil_caz
    I am very interested can you please take pictures of it and post it so that ill know which one it is or these guys can help me out.
    PLEASE!!!
    i eat rocks
    im at "work" but when i get home i will for sure do that.
    only problem is i might not be home tonight, i will try.
    Is it a loud hub?
    i eat rocks
    not obnoxiously no, but it sounds nice. and has good engagement
    Reputation: El Gordo's Avatar
    A Hope Pro 2 rear hub is about $200 new, if you looking for $120 like metioned the Aircorps are pretty good hubs my buddy has had a Atomlab wheelset all year with the AC hubs.. Can you get a Azonic Outlaw Hub?
    _________________________________________
    TRANSITION!!!!!!
    08 Blindside - Zoke 66
    07 Preston - Zoke 55 R
    Meh.
    Azonic hubs are just Formulas.
    a loud one for 120 USD .. check the used hubs you might find something .. Formula hubs, well actualy all the hubs that use the KK interns are horrible .. stay away from them .. well i had bad experience with ... i will recommend you idk ... stay between Hope,Hadley,CK,Dt swiss, but idk if they make the size you need .. check used part for 120 you wont find any quality at your LBS
    i eat rocks
    here is the image of the hub.
    Reputation: 006_007's Avatar
    just put a credit card on the seatstays rubbing against the spokes if you want it to be loud.
    Reputation: Ghaleon109's Avatar
    Why is atomlab is saying Aircorps run $210 for a 135mm rear hub then...
    Can anyone tell what kind of hub it is?
    Its a 6 bolt right?
    Meh.
    Quote Originally Posted by MTB_prodigy
    Its a 6 bolt right?
    Probably a XC Disc or Mono.
    Yes.
    Five is right out
    ill check it out
    In which case, a Hope is what you need. I've had two- XC and Bulb, and they have been louder than any other hub I've come across.
    the goose is loose!
    Reputation: rm_racer's Avatar
    Feb 2006
    looks like a hope xc or an older model hope. i could be wrong though. from what i hear they're good, just a bit heavier than the pro 2. i have the pro2 hubs and they rock. that one looks like a good deal though
    Quote Originally Posted by rm_racer
    XC? will this hold up? Plus im using a grimeca 6 bolt rotor and a 9 speed cassette? This wont give me any problems right?
    the goose is loose!
    Feb 2006
    yeah the xc will hold up. it's just a name. that's if this is a hope xc hub.
    Meh.
    Won't work. Hope just barely offsets their bolt holes so that nobody else's rotors work.
    Yes... it's fine with your current rotor and cassette.
    Hey will do u think its a hope xc too?
    Five is right out
    http://www.hopetech.com/products/dis_02.htm
    Im really considering buying it.
    Would you guys but it?
