need longer cables on hayes strokers- Mtbr.com
Results 1 to 10 of 10
    well i bought some hayes strokers and the cables are too short. How much does a shop ussually charge for replacemnt? i could just take it home spring break and do it myself if its terribly expensive
    Peace Coast Style
    Reputation: Heals120's Avatar
    You'll need to install new hoses as well as rebleed the breaks. If you have no idea what you're doing definately leave it to your shop. It shouldn't cost you too much. Depends on what hoses you get. Like, just a standard Hayes hose won't cost too much, but Goodridge hoses will definately lighten your wallet a few.
    Quote Originally Posted by Internal14
    Ever slip a pedal and slam into the seat? That little thing would disappear until I later got to the ER.
    Calm Like a Bomb
    Reputation: pipes10's Avatar
    the thread title and your post is confusing....do u need longer lines or are they too long??
    '17 Hatchet Carbon
    '17 Troy Carbon
    '16 Django Carbon
    '16 Wilson
    '16 Farley 5
    https://www.instagram.com/jayparrington/
    Paste eater
    Reputation: Jwind's Avatar
    Mar 2006
    If they are too long, just cut them and bleed them and be done with it... Or have a shop do said job. easy and cheap....
    The Beaver
    Reputation: Mwehahaha's Avatar
    cables on hydraulic brakes... interesting. Ok I am just messing with you.
    Just take them to your LBS and they will set you up.
    Specialized P.1
    Specialized Demo
    THE LINES ARE TOO SHORT. my bad
    can you guys estimate about how much it will be? Ive done a lot of work on cars and stuff so im sure could do it but i dont have a pressure bleeder here at college. I could just take them back with me over spring break though
    anyone know a source for stock hayes lines? will i need a whole kit or just the bare lines?
    i was thinking i should just shorten the back line to fit the front and buy a new line to use for the back brake
    LDH
    LDH is offline
    Reputation: LDH's Avatar
    the rear line can be cut and used as the front if you need the front also that way you are only buying one line kit and one ferrule.
    Glad to Be Alive
    Quote Originally Posted by pipes10
    nah
    need longer cables....my hoses r 2 short
    i think i might just resell these on ebay (where i bought them) and buy some with long enough lines. I will just stick the rear on the front for now so i can get the bike sorted out and ill buy some with longer cables before spring break is over.
    The job isn't really all that cheap unfortunately. Most shops would charge around $25 a wheel to bleed, plus a bit of labor to install new hoses & fittings. I'd guess between parts and labor you'd be looking at $75 - $125 depending upon the region of the shop. My advice would be to make buds with a local tech and figure out his taste in delicious microbrews.
