Need help with bottom bracket- Mtbr.com
Results 1 to 8 of 8
    Reputation: MTB_prodigy's Avatar
    I have an 03 SC bullit and i need to get a new bottom bracket. I currently have raceface prodigy dh cranks and bb on it. This will fit right? Just want to make sure.
    http://www.jensonusa.com/store/produ...m+Bracket.aspx
    Yes, it will fit.
    -> SickLines.com <-
    Reputation: mtb_biker's Avatar
    Make sure the spindle width is the same as your current bottom bracket.
    Pivotal figure
    Reputation: kenbentit's Avatar
    Jan 2003
    You're good to go..
    Desert Sunset Calls/Upward, Pain, Perseverance/Welcome Solitude
    Mar 2005
    Listen to Jason..
    that BB is a 118mm spindle. Your frame has a 135mm rear hub, and thus should have a 113mm spindle for the 47.5 mm chainline that the 135 rear gives.
    This bb will put your cranks 2.5mm further out than ideal. It will work, but it is not the 'correct' bb for the application, and thus not ideal.
    Quote Originally Posted by davep
    Listen to Jason..
    2.5 mm doesnt sound like much. Will it affect the performance or get damaged or damage other components? Pricepoint doesnt have the 113mm bb. I cant spend much more than 40 plus shiping and tax.
    I just read on the product description and it says they only come with a 118 mm spindle. What other BB can i use that doesnt cost too much?
    I found out that the FR version has the 113mm spindle but the reviews suck. WHat else can i get?
