My crown race on my headset is too loose?- Mtbr.com
Results 1 to 19 of 19
    We get titles?
    Reputation: upNdown's Avatar
    I just installed a Cane Creek S2 headset on an old Super T and was able to press the crown race all the way to the crown with only my thumbs. Seems to me thats too loose. I tried the race on a newer Manitou steerer and it was equally loose on that, so I don't believe its a problem with the Super T steerer. Anyway when I got the fork completely installed, there was play there. When I held the brake and pushed the fork back and forth, you could see the crown race moving. I fired an email off to Cane Creek, but I'd like to know if anybody here has ever had this problem and if anything can be done about it. Is it a problem with the S2, or do I just have a bad race, or what?
    Thanks.
    Frequent Crasher
    Reputation: SuperBad's Avatar
    Idea!
    Quote Originally Posted by upNdown
    Thanks.
    Are you sure you used the crown race and not the piece that goes at the top of the headset? There is a very similarly shaped piece that goes on just before the cover. I think it helps to put the preload onto the top bearings.
    SB
    We get titles?
    99% sure...
    Quote Originally Posted by SuperBad
    SB
    I'm 99% sure. I mean, I installed it in the order it came out of the package. And CC packages their headsets nicely. Besides, the rest of the headset fits together perfectly and functions perfectly. I don't believe thats my problem.
    i doubt it, some races seem to go on tighter than others with certain steerers. If you can remove the race by simply slidding it off with no effort, or spin it with your fingers, then its possible the race is off spec. The fact you can see the race shift most likely means you didnt tighten or install the headset together properly.
    We get titles?
    Quote Originally Posted by zedro
    As I said before, I can slide the race off with little effort, so I'll thinking it is out of spec. I'm just looking to see if others have had this problem; with this particular headset or others. Or if there's anything I should know about installing a dual crown fork. But like I said before, I'm pretty sure the headset is tightened and installed properly.
    why not simply call Cane Creek, on the phone...
    and tell them the story. Chances are they will probably send you a new crown race for free(they're cheap).
    Reputation: Polk's Avatar
    That is definitely too loose. I would recommend not riding the bike like that.
    It sounds like that particular crown race is has been machined incorrectly. Just a couple months ago I put the same headset on a 2002 Manitou Mars and it went on with the usual force.
    ok, i thought you meant just for installing it. Cus i can hand install my Pig DH on my Shiver but the thing stays put.
    Doesnt ride Banshees
    Reputation: Banshee Rider's Avatar
    If this is the same little ring that im thinking of, i thought you had to have a tool to pound it on? Whenever i go to my LBS to switch/put on a new fork i have to take the ring off one fork and pound it on to the new fork using this park tool thing, its like a 20in long pipe with different fittings that go on the end and you bash on that little ring a couple times. By the sounds of it pushing it on with your fingers just aint gonna make it stay put and thats why your feeling that play when you put on the fork. thats the only thing i could think of.
    We get titles?
    Quote Originally Posted by Banshee Rider
    Right, that is my problem. No tool will install that race any tighter than I've done with my fingers. Its pushed all the way down, flush against the crown. Forget about this email crap, I'm calling CC.
    Bike Hoor
    Reputation: Innocent Bystander's Avatar
    I would call/email CC, no question, as I have installed numerous S2 headsets and never had this problem. I have read before that some mechanics install crown races by using a bit of Loc-tite green (press fit strength) to ensure that this is not a problem.
    Pedalling the goods since 2002.
    http://www.boutiquebikes.com
    Jm.
    Jm. is offline
    If you are curious UpNdown, I was using a Cane Creek C2 on it, it was plenty "tight". I don't think I've ever owned a fork where it only took hand-pressure to put the race on, it's always been a "press" fit, just my personal experience.
    wheeeee!!!
    Reputation: butocabra's Avatar
    one exception...
    only exception I can think of is an fsa sealed bearing headset, where the crown race was actually a split ring, and you could put it on with hand pressure. Still, assuming the crown race you're looking at isn't a split ring, it sounds a bit loose to me.
    LT1
    LT1 is offline
    The same thing has happened to me with all my Pig crown races, I can almost always install them by hand or very little pressure (on a wide variety of forks) and I've never had a problem.
    large member
    Reputation: sub6's Avatar
    In 100% of the headsets I've installed, including FSA sealed-bearing headsets, the split-ring is for the UPPER race. It is NOT the crown race, it only serves to center the steerer tube in the upper race.
    ~~HCOR.net~~
    East Coast, beyotch!
    Quote Originally Posted by sub6
    as i recall, some headsets have a split-race, not the split ring your thinking of. Not quite sure where i remember this from tho.....
    We get titles?
    Thanks.
    I called Cane Creek and the guy didn't seem to think it was possible for them to manufature a race that's too big; he thought that since it was a used fork that the steerer tube had been worn by the previous race. That wouldn't explain it being loose on my other fork, so there is no explanation. But he said he'd send me out a new race, so I wait and see I guess.
    wheeeee!!!
    we're talking about two different parts...
    In an fsa orbit II headset both the upper ring that preloads tension on the upper bearings, and the crown race itself are split. I think the orbit is the exception, though, as the pig dh on my other bike had a normal crown race that had to be seated.
    We get titles?
    AHA! It was the race...
    I got the free replacement race from Cane Creek and it was much tighter. Took me quite a bit to get it seated on the crown - I didn't have the proper tools, so I just put the old race on top of the new race, put a screw driver on the old race and hammered it home. Worked great though; no damage to the new race and it is pressed in there tight.
    So I reinstalled the fork, stem, etc...and the play I was experienceing has disappeared. So thanks Cane Creek for the replacement race. My lesson for the week is "Never trust a crown race that you can push on with your thumbs."
  1. When is YOUR first race????
    By Tryin2B in forum XC Racing and Training
    Last Post: 02-24-2004, 08:43 PM
  2. My 8$ crown race setter...
    By sodade in forum Tooltime
    Last Post: 02-14-2004, 03:54 PM
  3. RockShox SID RACE 03 Knocking
    By Sorted in forum Shocks and Suspension
    Last Post: 02-12-2004, 12:39 PM
  4. Replies: 18
    Last Post: 02-08-2004, 12:19 AM
  5. help...headset cup loose
    By erol in forum Singlespeed
    Last Post: 01-18-2004, 07:04 PM
