Is my 6 way done for?- Mtbr.com
    "The Freak Show"
    Reputation: MM_Freak's Avatar
    Feb 2006
    I was tinkering around with my Manitou swinger 6 way today and as I adjusted both the low and high speed compression knobs a little bit of fluid would come out from under the knobs as I turned the knobs. It dose this every time I turn the knobs, so is there a blown out seal or something? Thanks for any info provided.
    Go big or go home in a wheel chair!
    Info on 2011 racing season
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    If it's not leaking dont worry.
    Sounds like you are getting seepage past the shaft what adjusting, most likely side to side play allowing the fluid to seep by.
    Formotion Products
    http://www.formot
    "The Freak Show"
    Feb 2006
    Yeah.........well just got back from a little ride around town and now I've got oil on everthing and its making strange noises now but I was ready for a new rear shock anyway. Thanks for the help. I think Im gonna look into a roco tst for the my big hit.
    Jan 2005
    Track down HAB he has been using a Fox DHX-5.O Coil & is going to be getting the Roco. Should be interesting to get a opinion on a back to back shock comparison.
    Formotion Products
    http://www.formot
