Michelin Comp 32 2.8" tires & Intense Mag 30 rims - Tubeless?- Mtbr.com
Results 1 to 3 of 3
    Hello all,
    I have a set of Michelin Comp 32 Soft 2.8" DH tires on a set of Sun Intense Mag 30 DH rims. Does anyone know if I can convert my wheels to tubeless with this tire/rim combination? And if so, how should I go about doing it?
    Thanks in advance.
    Try here
    www.notubes.com
    Call Stan and ask about your rim width, though.
    -T
    TNC
    TNC is offline
    noMAD man
    Reputation: TNC's Avatar
    Unless it's some ancient model, it's tubeless.
    Quote Originally Posted by Freerider
    Hello all,
    Thanks in advance.
    Does your sidewall have the term "Nagesti" or even tubeless UST on the sidewall? The last one I bought was at least a year and a half ago, and it was marked this way. Even if it's not, I guarantee you this tire is beefy enough and with a strong enough bead and carcass to easily run tubeless. I've only run this tire on the front. I've used a WTB 30mm Dual Duty rim and even stuck it on a Rhinolite--seems like it'll go on just about anything except maybe a very narrow XC rim. It's always been run tubeless and may be the best tubeless tire candidate out there. The dang thing's a motorcycle tire--almost. You can easily run that tire on just about any rim wide enough with one of Stan's slightly wider DH strips and some Stan's sealant. I had to use the wider strip on the WTB rim because of its width. Go to Notubes.com to see how it's done--it's easy. I haven't run a tube in any of my 3 bikes since October 2001 when Stan's was just a homemade deal with some hobby shop latex. Stan's new sealant is better and not as messy as the old latex formula.
  1. Bontrager Tubeless wheels
    By Dan Gerous in forum Trek
    Last Post: 03-24-2004, 01:46 PM
  2. Michelin Comp 32 tires & Intense Mag 30 Rims - Tubeless?
    By Freerider in forum Wheels and Tires
    Last Post: 03-23-2004, 10:21 AM
  3. Can I use my tubeless tires on standard disc rims?
    By siochain in forum General Discussion
    Last Post: 02-28-2004, 12:22 PM
  4. Looking for the Michelin Comp tires..
    By NoVA-b in forum Wheels and Tires
    Last Post: 01-28-2004, 11:50 AM
