Marzocchi ROCO TSTR- Mtbr.com
Results 1 to 6 of 6
    Reputation: Chumba15's Avatar
    Marzocchi ROCO TSTR
    Anyone know how much this weighs, it's on a 2007 Kona Stinky Deluxe? Anyone know how much the Fox DHX 5.0 Weighs?
    sixsixtysix
    Guest
    Quote Originally Posted by Chumba15
    Does it really matter if its on a Stinky? Its a coil shock, the coil on it is going to make more difference than the shock body itself.
    Quote Originally Posted by sixsixtysix
    How much weight would I save switching to a titanium coil?
    sixsixtysix
    Guest
    Again, it depends. The Zoke coils weigh more than the same Fox coils but you can run them on each other. Best way is to find the weight of the shock body and then add the weight of the coil.
    Reputation: lalocotequinta's Avatar
    About 30-40%.
    Glad to Be Alive
    Honestly....r u high??? you asked this in another post....
    the fox dhx 5.0 is the most overated shock.....no small bump sensitivity and mid stroke harsh......Marz way better....don't swithch they weigh the same...get a ti spring
