Marzocchi roco ???- Mtbr.com
Results 1 to 8 of 8
    New question here. Marzocchi roco ???
    okay so i have a 08 giant glory fr with a rock r on the back the spring it says 550x2.75 on the coil. so could i use a 450 ti coil. im 145 lbs and never bottom out now. thoughts thanks.
    "Ride Life Ride Giant"
    Oct 2007
    only if:
    1) you want a softer feel with the lower spring rate
    2) the ti spring is 450x2.75
    it is 2.75 but will i bottom a lot. is it too soft.
    Oct 2007
    er... i dont know. look on giants website for a weight/spring rate chart.
    how much sag are you getting right now on the 550#?
    moaaar shimz
    Reputation: tacubaya's Avatar
    Get a better shock.... like a Roco WC
    im not sure of the sag level probably about 25 percent because its so hard to adjust but im not interested in the shock quality im actually very impressed and happy with it.
    Oct 2007
    you probably want a little more sag so 450# would be fine
    ideally you want 30-40% for FR/DH
    should probably have a friend help you out and measure sag before spend the coin on the ti spring
    oh and i second the notion to get a better shock. Roco WC is butta =)
    yeah i have a friend actually the one who is selling the shock i ride with a lot. i really dont think it would be too light.
