marzocchi 888 rebound adjustments- Mtbr.com
Results 1 to 8 of 8
    KOKOPELLI RACING
    Reputation: doubledecadefirehydrant's Avatar
    i just had the 888 put on my v10; however, the rebound dial at the top of the right fork leg doesn't want to turn (right now, the rebound is ridiculously slow). i read the manual and it says not to force the knobs. is there anything i can do??? is there something wrong w/ the fork?
    try to remove the allen screw on top of the knob. There may be some debris blocking the knob from turning
    Stack Daddy
    Use a little force
    Quote Originally Posted by doubledecadefirehydrant
    with your hands only. If the knob has been turned a little to hard to the end of its threads it will 'stick'. Just put some oomp into it one direction or the other, it should go. The parts are all metal so it's fairly strong. Just don't get out the vicegrips!
    Former Noob Herder
    Reputation: zedro's Avatar
    read the manual, there is a knob 'lockout' so people dont screw with your adjustments.
    Quote Originally Posted by Gunslingger
    no doubt you must have majored in english or something rad!!!
    Stack Daddy
    zedro, sir.
    Quote Originally Posted by zedro
    Is this the correct way to address a mountie? I have looked in my manual for said lockout and can't find it. Please illuminate me with a page # or explanation. Thanks.
    Former Noob Herder
    Quote Originally Posted by Dirtdemon
    sorry, swear i thought i saw it mentioned. Anyways, there are little grub screws on the side of the knob you have to loosen. If those are loose, then someone overtightened the knob in either direction; thats a bit of a crap-shoot.
    KOKOPELLI RACING
    thanks, guys. i'll try and see if your suggestions work.
    KOKOPELLI RACING
    thanx!
    zedro's suggestion worked like a charm - thanks for all of your input!!!
  1. marzocchi 888 rebound adjustments
    By doubledecadefirehydrant in forum Shocks and Suspension
    Last Post: 12-26-2004, 09:37 PM
  2. Marzocchi makes a tripple 888 Low rider Crown?
    By Max_winner1 in forum Downhill - Freeride
    Last Post: 12-17-2004, 07:00 PM
  3. Lost my Marzocchi MX Pro ETA rebound adjustment knob...
    By BruceBrown in forum Shocks and Suspension
    Last Post: 09-16-2004, 05:15 AM
  4. Whistler and 2005 Marzocchi Line
    By Photo-John in forum Downhill - Freeride
    Last Post: 08-10-2004, 03:46 PM
