marzocchi 888 adjustments- Mtbr.com
Results 1 to 3 of 3
    I can ride a two-wheeler
    Reputation: thomasmunka63@hotmail.com's Avatar
    I have a 2005 marzocchi 888 vf i just got for $300 brand new
    i was wondering if there was a psi table for 2005 marzocchi forks online....the manual doesnt say how much psi they recommend for the 888line
    or if anyone has personal experience..... im a 125lb rider
    thanks
    Flyin' low
    Reputation: S_Huitt's Avatar
    I just bought the same thing a bit ago. An OK fork and a good price. These are not air sprung, so I'm not sure what you want to do. The only adjustments you can make are spring rate( coil springs ) and oil hight, Oh and oil weight. Higher spring rate will make it harder to compress. Heaver oil will slow damping. Higher oil hight will increas bottoming resistance. Other than that there is no other adjusments you can make.
    Again, the is no provision for air pressure.
    oooo...i thought there was air pressure like on my drop-offs...ill leave them the way they are then...o well
