marzocchi 66 ata 08- Mtbr.com
Results 1 to 14 of 14
    Reputation: JC bs's Avatar
    Oct 2007
    marzocchi 66 ata 08
    i just got these forks a few days ago. so far no good they have a shake or play in them they also have a sag them. i have played with the all the air settings andf nothing good. i guess beside the front end of my bike feeling loose all the time there ok.
    does anyone know what i could do to get these things dialed in besides buy something else
    Trying a little
    Reputation: dusthuffer's Avatar
    Nov 2006
    give up biking, take up skiing
    I never apologize. I'm sorry, but that's just the way I am.
    StraightOuttaCompton
    Reputation: Djponee's Avatar
    nope, just put them on your wall and let them look sexy,and then get yourself some 66 rc2x, very nize!!!
    HARDTAIL PRIDE- 09 Kona Five-0
    Oct 2007
    Quote Originally Posted by dusthuffer
    no thanks i was thinking more about bowling hahaha
    Living Ghetto Fabulous!
    Reputation: Uncle Cliffy's Avatar
    Quote Originally Posted by JC bs
    Next time, use capital letters and proper punctuation so I can understand your problem.
    Quote Originally Posted by kidwoo
    The internet sounds like a tough place to ride.
    Reputation: creyc's Avatar
    May 2005
    They have a sag? Like when you sit on the bike it compresses somewhat? I'm pretty sure that's what it's supposed to do...
    As for the axle call Marz, some people have been having this problem. They'll send you a new axle.
    Meh.
    Reputation: XSL_WiLL's Avatar
    Play? Sounds like bad or missing bushings.
    Reputation: dowst's Avatar
    Good 'ol Marzocchi!
    Meh.
    The sad thing is that I'm not joking.
    Oct 2007
    Quote Originally Posted by Uncle Cliffy
    my bad
    Oct 2007
    when your off the bike they sag about 1/2in when you pull up hard it make a slight clunk.
    sounds like the wrong air pressure settings are sucking your fork down on the stanctions a bit - negative travel. i had this too when i played with the air settings. try filling the par chamber first - 70-100psi and then the main air chamber 45-70psi and don't touch the RC3 chamber unless you are 200lbs plus. obviously par must be greater than main air chamber. let the air out and start from scratch on the par and main.
    N* Bomber Crew
    Reputation: Raptordude's Avatar
    I still see the SL ATA system has glitches. I'm going to steer clear for my new DHR.
    Northstar 2008 Riding Crew
    lol
