Manitou Swinger Coil CREAKING ???- Mtbr.com
Results 1 to 10 of 10
    GT.
    GT. is offline
    work hard, ride free
    Reputation: GT.'s Avatar
    Hi, guys.
    One of my friends have a Manitou Swinger 4 way coil on his bike. I noticed that it makes some weird creaking sound when I ride it or even sit one it. We checked everything out and it turned out that the RESERVOIR itself make the creaking sound. It also trembles a bit when the shock is compressed and I can feel it clearly with my hand on it. I have never seen or heard of anything like this before. The shock is pretty new, too. What do you guys think of this? Any advice would be very much appreciated. Keep riding~
    GT
    Authority is dead!
    Reputation: Lucky13's Avatar
    no good
    loose resevoir isn't good. Call Manitou, they are very friendly and will help. The worst case is that he will have to send the shock to get it fixed.
    For the love of Oi
    Rent a house at Attitash
    TNC
    TNC is offline
    noMAD man
    Reputation: TNC's Avatar
    Hmm...define creaking and trembling.
    Quote Originally Posted by GT.
    Hi, guys.
    GT
    Why I ask that is because these stable platform style shocks definitely make more odd sounds than any other shock I've ever owned. I currently have 2 5th Element coils and 1 Swinger 4-way air. There's some work going on in there during the beginning compression portion of shock travel, and of course this usually occurs more frequently and noticeably when you're going slower or even just sitting still and bouncing the bike. In this stage of compression, these shocks definitely make some weird noises, especially on the rebound stroke from this beginning compression stroke. I've never held on to the reservoir to test if this action is noticeable to the touch, but it may be possible. A small amplitude vibration might be felt under these circumstances. Obviously if the reservoir is acutally "loose", then you have a different can of worms. Just curious, because it's often quite hard to diagnose descriptions of perceived sounds over the internet as opposed to actually getting to see or hear it yourself.
    GT.
    GT. is offline
    more about the creaking trembling
    Thanks for the concern guys. I should have been more specific about the creaking and trembling. It's not like the usual sound of the damping system working in any type of rear shock. It's sounds like an old wooden door with rusted hinges opening by breezy wind. Try to imagine a scene from a horror movie. ;-) And the trembling is very weak but it's definitely coming from the reservoir itself when the shock is compressed. I can't feel anything on the shaft, spring, collars, bolts, linkages. Well, he's going to call the manufacture on Monday. Well, wish him good luck. Thanks again guys. Keep riding~
    GT
    Reputation: dostres's Avatar
    Does it creak when he rides it?
    Or just when you ride it... it could be that it is set up for his weight and not yours. It also could be that the coil is not heavy enough for you/him or both of you.
    Former Noob Herder
    Reputation: zedro's Avatar
    sounds more like the damper pivots too me. I have a hard time believing a high pitched creek could come from inside someting filled with oil.
    GT.
    GT. is offline
    Thanks guys
    Thanks for the input guys.
    dostres; It creaks regardless of the rider weight. Actually, it creaks even when I push down the bike a bit with my hands.
    zedro; Yeah, it is high pitched creak. (Why didn't I came up with that words before?) But it sure comes from there. By the way, what is the 'damper pivots'?
    I'll post again once we find out what the manufacturer says. Keep riding~
    GT.
    Former Noob Herder
    the shock eyelets, the holes that the shock mounts itself to. Most of the time they are responsible for creeking.
    Reputation: gonzostrike's Avatar
    I agree with Zedro
    I'll bet it's the damper pivots, too. there's probably some dust in there too, in the bushings/eyelets.
    Reputation: Flava's Avatar
    Dude, i have had the same thing with my swinger. it was the spring rubbing on the shock body. check to see if there are any marks on the gold part of the shock body. I just had to recenter the spring and it went away.
  1. Fox Float RC or Manitou Swinger Coil SPV 4-Way
    By K2theG in forum Downhill - Freeride
    Last Post: 04-19-2004, 10:03 PM
  2. Swinger 4way coil vs 3way air shock
    By Dirtman in forum Giant
    Last Post: 04-03-2004, 05:28 PM
  3. Replies: 2
    Last Post: 03-03-2004, 09:07 AM
  4. Manitou Swinger Coil
    By Deimos in forum Shocks and Suspension
    Last Post: 02-10-2004, 01:13 PM
  5. manitou swinger, coil or air???
    By TONYACCURSO in forum Shocks and Suspension
    Last Post: 01-21-2004, 09:21 AM
