Manitou Swinger 3-way- Mtbr.com
Results 1 to 3 of 3
    Hey whats up! Ok so here is the deal i have got a raleigh ram 1500. The bike is super plush in the rear but bottoms out. I put the shock into the 5 in position and it firms it up and makes it bottom but is definately not as plush. Now i have talked to a couple of people and have heard a couple of diffrent things. I have heard that if i was to get a shock pump and put more pressure in the air chamber it would stiffen it up. On the other hand i have heard that putting air in the chamber will not make it any stiffer, just make it resist pedal bob more. Which is correct?
    thanks
    Reputation: NCBigHit's Avatar
    Adding some air will make it less sensitive to small bumps with the bonus of better pedalling efficiency, and will stiffen it up a little, but not a ton. If you are consistently bottoming, you should probably get a little heavier spring.
    If you don't own a shock pump, you should prob get one just because if you run the rear shock with under 50 psi, you can damage it.
    Yea definitly get a shock pump so you can adjust it depending on where you ride. If you need to make big changes then go with a new spring.
  1. blast from the past, cut/paste from archived MTB DOC posts
    By ashwinearl in forum XC Racing and Training
    Last Post: 02-09-2005, 09:47 AM
  2. Help me with the manitou swinger 3
    By dtrek4500 in forum Riding Passion
    Last Post: 12-29-2004, 10:23 PM
  3. Manitou Swinger 3 way - what weight spring?
    By jungleuk in forum Downhill - Freeride
    Last Post: 04-20-2004, 07:26 PM
