mainshimstack dhx 5 coil 2007- Mtbr.com
Results 1 to 5 of 5
    hi everybody, sorry for my bad bad english..i've a problem with a rebound of my fox dhx 5 coil..i've change the oil and i've doing some error when i've mounted the mainshimstack, now i've not a breaked rebound..
    is correct the assembling of mainshimstack in the photos?
    I believe you need to turn the piston around. When your holding it like in pic 2, just put the bolt in the other way, and install on shaft. The big holes should be facing up. Looks like the shims are on correctly though.
    it's correct?
    this
    or this?
    Reputation: Nick_M2R's Avatar
    Yep, in the first pic, you had the piston upside down
    The way you have it in the last pic is correct
    thanks !!!
