M6 question if you own one- Mtbr.com
Results 1 to 7 of 7
    Reputation: boogenman's Avatar
    Just ordered a M6 and was told to get a 450lb spring for the CCDB, I called Cane Creek and they told me to go with a 350lb? So I am confused, I am going to go with what Cane Creek told me but I am not sure.
    What springs are you guys running and what is your weight?
    I am about 205lbs with gear maybe 210 if I need to poop.
    N* Bomber Crew
    Reputation: Raptordude's Avatar
    I think it's a smarter idea to go with what the manufacturer suggests. Different designs yield different spring rates. Turner told me to do either a 400 or 450 on my DHR, and I weigh 180.
    I think the 450 is a more accurate rate for a 210 lb. dude. You could step down to a 400 if you dare, but the 450 just seems more realistic.
    Northstar 2008 Riding Crew
    The Beaver
    Reputation: Mwehahaha's Avatar
    I would trust Cane Creek... they know what they are doing.
    Doesn't the m6 use a longer than average shock? this might come into play... here is a calculator if you want to play with the numbers. http://www.igorion.com/_coilspring/
    Specialized P.1
    Specialized Demo
    Quote Originally Posted by Mwehahaha
    Calculator also says 350
    The Beaver
    I have found that calculator to be right on for my DH bikes... Coils are relatively cheap, you can always switch them up.
    Specialized P.1
    Specialized Demo
    the more I play with the calculator the more it seems to be accurate. It almost seems like malcom was using the same calculator when I was talking to him yesterday.
    When I put in the info for my current shock(another CCDB shorter stroke) I get 450lb spring, that it what I have no and that gets me to about 30% sag.
    Maybe I was talking to the sanitation manager at intense and that is why he said to go with a 450
    Ricky DH
    Reputation: rep_1969's Avatar
    That calculator is spot-on for my weight and bike.
