Lowest Seatpost Seat Combo- Mtbr.com
Results 1 to 19 of 19
    I got short legs so every inch counts. haha I'm talking about the seatpost/seat combo height... I'm looking to get a little bit more clearance. My shorts hook onto my seat from time to time when moving behind my seat and back which scares the crap out of me.
    Someone suggested using a bmx style pivotal seatpost and seat combo. Anyone have experience with these? Is this the best solution for what I'm looking for?
    I was thinking of maybe even experimenting with this triathalon seatpost and running it backwards so the seat is racked back...
    http://www.jensonusa.com/store/produ...+Seatpost.aspx
    Any ideas? Thanks.
    clyde in training
    Reputation: 08nwsula's Avatar
    sounds like you need a smaller frame more than anything
    meow meow
    Reputation: b-kul's Avatar
    yeah dude sounds like you just need a smaller frame. but my ea30 post and wtb shadow can get pretty low.
    Reputation: kipdrunner's Avatar
    Ziptie the seat right to the frame!
    Reputation: davesauvageau's Avatar
    I use a pivotal on my BMX bike and I love it! I also designed my own clamping mechanism for my post, you can find it here
    https://bmx.transworld.net/100007688...dge-seat-post/
    This could give you some clearance also, if you got ballsy enough to cut your frame!
    My motorcycle runs on infant blood
    Nov 2008
    was going to say, pivotal with a flush-style post (almost no flare) is probably as low as you're going to get. I know the DMR lockjaw comes in mtb sizes (27.2 specifically, easy to find shims for that). get a super thin saddle, and destroy your butt.
    alternatively, maybe try to find some shorts that fit better?
    Living Ghetto Fabulous!
    Reputation: Uncle Cliffy's Avatar
    I've seen some pretty low Thompson/WTB Silverado set ups. I think it's lower than some Pivotals... My friend took his Pivotal post to a machine shop and had them turn it on a lathe to get it even lower. Now they make some really stubby ones that have no machining to them, but good luck finding a shim.
    The newer I-beam posts slam pretty low too, but seriously, what bike are you on?
    Quote Originally Posted by kidwoo
    The internet sounds like a tough place to ride.
    Takw/agranofsalt
    Jan 2005
    SDG I-Beams offer a ton of adjustability. You might want to try one of those.
    Quote Originally Posted by Khemical
    That's what I'm using, I would definitely recommend it.
    Have you considered just the saddle your using. Some are easier to get behind than others. Also as someone else mentioned have a look at the shorts your wearing.
    Meh.
    Reputation: XSL_WiLL's Avatar
    Unless you lathe down the Pivotal post, it cannot be slammed. The seats are not exactly low either.
    My Thomson post with a Selle roadie saddle is over 3/4" lower than the same post with a WTB saddle.
    Bike Hustler
    Reputation: LoozinSkin's Avatar
    I have a cut down ibeam post I can sell you if you want to find a cheap belair for it. Definitly a low combo.
    http://www.pinkbike.com/buysell/491063/
    SHAM-WOW
    There are slammable options as well, such as these:
    http://www.danscomp.com/products.php...EATPOSTPIVOTAL
    Locs on Spokez
    Reputation: Iggz's Avatar
    Nov 2006
    Sounds like you F'd up on the frame-sizing there buddy
    But yeah, doesn't get much lower than a slammed pivotal.....
    Ground Steeze. @iggy_strbac
    Quote Originally Posted by davesauvageau
    Did you see what size those were?
    The seat tube of you typical MTB starts around 27.2 I.D. Stubby posts like these are much smaller and finding a shim for it is problematic at best... If you can find one, cool. Good luck!
    wow just got back in from a trip to all these helpful suggestions! i'm taking a look at all your suggestions now...thanks guys!
    Jan 2003
    Quote Originally Posted by 67rider
    Try less baggy shorts.
    Quote Originally Posted by Uncle Cliffy
    I know that, but Macneil makes a 27.2 post. I'm not dumb, I just expected you to be able to find other sizes. Several companies are making 27.2 pivotal posts or larger.
    I have a 27.2 Ceneca, but there aren't any "stubby" 27.2 Pivotals... If you find one, post it here cause I want it.
