Loose Pivot- Mtbr.com
Results 1 to 6 of 6
Thread: Loose Pivot
    Moose Member
    Reputation: Moosey's Avatar
    May 2010
    Loose Pivot
    The pivot on my porter is loose. Does anyone know what could cause this?
    Do i need moar shimz? and if so what material are best?
    could it be bearings?
    any help is welcome.
    Thanks in advance.
    yeah single pivot...tighten that fugar. I own x-6 haro...either the bearings or shock's bushings...
    Moose Member
    May 2010
    It's obviosly the pivot. Shock is fine. There was lateral play in the pivot. Anywho I took the whole rear triangle off and will check it tonight. Are there any shims or anything in your haros pivot?
    I'm probably going to email haro and see what they say...
    there's a sleve inbetween bearings and two washers between swingarm...could be shock bushings too.
    Moose Member
    May 2010
    what kind of a sleve?
    i just replaced the bushings....
    Picture Unrelated
    Reputation: zebrahum's Avatar
    Jun 2005
    Don't let it get loose. If you run the bike with slop in it then the bearings and bushing will get bad enough that they can't be repaired. A shim is just going to be a ghetto fix, do it right and don't risk your frame.
  1. Loose pivot on BR?
    By Thor Lord of Thunder in forum Transition Bikes
    Last Post: 07-29-2015, 05:21 AM
  2. Pivot Bearings loose, looking for help
    By aflax in forum Rocky Mountain
    Last Post: 05-07-2011, 06:33 AM
  3. loose element pivot
    By rubus in forum Rocky Mountain
    Last Post: 10-30-2006, 11:58 AM
  4. S.O.S. loose pivot
    By CarlosPR in forum Ventana
    Last Post: 08-03-2004, 12:11 PM
  5. Loose Pivot
    By shadfly in forum Downhill - Freeride
    Last Post: 05-28-2004, 04:26 AM
