Lightweight cranks?- Mtbr.com
Results 1 to 59 of 59
    -C-
    -C- is offline
    Lightweight cranks?
    Wonder if anyone else can help with a decision process here...
    I've been running RF Atlas AM cranks alongside Saints for a while now (with Shimano BB as its significantly better than the X-Type junk), but n a new build am looking to go a bit further on the weight savings.
    I am looking to go with either RF Deus, or XTR M970. I know people are running XTR's on big bikes & having no problems, is this the case with RF as well? Taking the rings out of the equation, like for like they weigh almost the same, so its a case of what to go for...
    StraightOuttaCompton
    Reputation: Djponee's Avatar
    i like the hozfeller oct w/ howitzer bb, very light and strong
    HARDTAIL PRIDE- 09 Kona Five-0
    Bike Ninja |||
    Reputation: chooofoojoo's Avatar
    Feb 2007
    Quote Originally Posted by Djponee
    and very flexy i might add. friend's crankarm flexed so much it' dented his chainstay on his demo
    they are light tho.
    Proud to represent Mojo Wheels.
    Reputation: Mikey_C's Avatar
    Mar 2005
    970 xtr certainly very bling for dh 770 grams is pretty nuts. But of all places to save weight Imho the crankset is one of the last places to do so. road rear der, fine, 135gm saddle, um ok but cranks take a ton of abuse from rider and trail. there are alot better places to save 160 gms (hones are 928)
    thats being said FSA has some real light options for 08 in their gravity line up and fsa has a better bb than shimano(again imho)
    with the $200 you will have left over for weight savings in other places
    -C-
    -C- is offline
    I'm at one of the last places to save weight now though, so it has to be an option...
    I've seen a few bikes running them & no noticable flex talking to people, but i'm not sure of this would be the case with the equivalent RF offerings.
    The more I think about it, the more i'm talking myself into dropping some silly money into a set
    Mar 2005
    whats your bike/build? sounds like its baller...whats the specs? pics?
    hey im all about silly light weight part i got juicy ultimates for a dj/park bike so im not attackin you. just giving my 2cents
    Reputation: El Gordo's Avatar
    Quote Originally Posted by chooofoojoo
    they are light tho.
    I am 240lb and been beating on my Holzfellers OCT w/ Howitzer Team BB and have had no problem not one sign of flex and I ride pretty hard .. Where they older model? How did they flex that much to screw with his chainstay. Thanks for the info
    _________________________________________
    TRANSITION!!!!!!
    08 Blindside - Zoke 66
    07 Preston - Zoke 55 R
    Quote Originally Posted by Mikey_C
    How many cranks(not BB's) have you seen fail?
    Mar 2005
    Quote Originally Posted by Rover Nick
    i never said anything about crank failure. im talking about reliability and stiffness.
    but to answer your question
    fail: only a profile arm
    become unridable, ie bent arm, broken pedal insert, etc....many
    moaaar shimz
    Reputation: tacubaya's Avatar
    Hones if your BB lenght is 73 mm or less and you are light
    Saints if you are heavier.
    Hollowtech II pwns
    Locs on Spokez
    Reputation: Iggz's Avatar
    Nov 2006
    Shimano Cranks >>>>>>>>>>>>>>>>>>>>> Truvativ Cranks
    Get a XT crankset, light and stiff. Used to have some Stylo's but they flexed like **** and the nondrive side actually developed play forward and back which is a joke...
    Ground Steeze. @iggy_strbac
    -C-
    -C- is offline
    Quote Originally Posted by tacubaya
    Hollowtech II pwns
    Already have Saints, too heavy, as are Hones.
    I want light, seriously light. I expect to compromise an element on longevity, I am realisitic.
    The new XT crankset is possibly an option, but it would let down the rest of the build...
    they are light tho.
    maybe the demo rear tringle is flexy!
    :thumbsup:
    ride.
    Bum Buzzer
    Reputation: Huck Banzai's Avatar
    May 2005
    Im a 240lber looking to do some lightening too. Just came from the FSA Gravite Lite thread. I want to use them on a bike that will see decent drops and jumps, but 'known' lines and alot of smoothness... I like my burly saints, but Ive never been a part masher despite my size (the occasionaly rear wheel in 1 hit killer tho) so I want to be able to climb and get around more.
    XT's, Hones, FSA Grav Lite, RF Atlas, are all considerations. Anyone want to try to make a scale of strength and weight on these puppies?
    Reputation: gremlyn's Avatar
    Feb 2007
    they are light tho.
    I'm 190lb and there is no way that I can feel any flex on my OCT what ever I do to it. Maybe your freind had some old and/or defective cranks?
    btw, how in the hell did he manage to dent chainstays on demo?!
    I'm not a complete idiot, some pieces are missing.
    Mar 2005
    Quote Originally Posted by -C-
    u tease...when are we goin to get pics of this bike! sounds like you are sold on xtr just do us a favor and get us some pics
    Reputation: Hardtails Are Better's Avatar
    May 2005
    Quote Originally Posted by Huck Banzai
    I'll try. IIRC, weight is as follows. FSA>Hone>Atlas>XT. Strength wise, FSA wins bonus points for the steel pedal insert, as does the 2 ring Hone. That said, the shop I work at has seen several f'ed up FSA road cranks recently. 1 with toasted pedal threads out of the box, 2 with mangled splines on the BB interface, and 1 bent arm. One guy I ride with has broken 2 Afterburners in as many months. This is the extent of my experience with FSA's cranks, and it's not good. IIRC the Hone has an aluminum spindle, whereas the XT is steel, so the XT might be a little better there, but I've never heard of anyone breaking the spindle on any external bearing crank, so it's probably not a big deal. I remember somthing about the Atlas had some issues with shatty machining on the arms, which, if bad enough, made them nearly impossible to take off. I'm a little fuzzy on the details, but I'd look into that.
    My verdict: XTs FTW. I love mine.
    -C-
    -C- is offline
    It's just a pile of bits at the moment, so nothing to take pictures of...
    When it's built though, i'm sure it will be nice
    Just trying to broker a deal on some arms & BB now, as I obviously don't need the stupidly expensive chainrings.
    Reputation: kntr's Avatar
    FSA Gravity Lites work for me
    Reputation: BlueRidgeRider's Avatar
    Dec 2004
    Cranksets
    Go with the new XTR's...I run RF Atlas on my Socom, they hold up pretty well to East Coast racing.
    I was thinking about XTR's myself, I only weight about 160 though and I'm easy on parts...most the time
    -C-
    -C- is offline
    I reckon i'm about 190 kitted up & i'm pretty a pretty smooth rider, so i'm hoping they should be more than able to cope...
    And i'm running out of areas to save weight now as I don't like the thought of carbon bars & seatposts on big bikes.
    Dec 2004
    bars and posts
    I run Easton carbon DH bars and the Easton carbon post...no worries. Having the carbon bar does bother me a bit, but I check it frequently.
    I'm switching to lighter wheels as well, I'm shooting for around 37 pounds. Right now, I'm just a bit over 38. My scale reads 38.16.
    https://i219.photobucket.com/albums/...v/DSC03107.jpg
    Here is the actual 38.16 setup, the photo above was without Acid 2 pedals and the Ti spring.
    https://i219.photobucket.com/albums/...v/DSC03274.jpg
    middleburns are suppose to be pretty light
    64,999,987 firearms owners killed no one yesterday.
    Broken and dizzy
    Reputation: Surfinguru's Avatar
    they are light tho.
    Um, Hussefelts maybe, but I'm not seeing that with a new pair of Holzfeller OCT's.
    -C-
    -C- is offline
    See, i'm hopefully shooting for 34.something with the complete spec.
    Ti Spring
    Burgtec hubs on Mavic XM819 rims DT DB Spokes
    Maxxis 2.3 UST High Rollers
    Totem Solo Air
    Thompson Elite X4 stem
    Easton EA70 bars
    Cane Creek Double X 1.5" Headset
    Full SRAM X0
    Dura Ace cassette
    SRAM hollow link chain
    XTR M970 cranks
    Easton Flatboy pedals
    E13 LG1
    E13 36T ring
    Shimano XTR M970 brakes, goodridge hoses, 203mm front 180mm rear, Aztec rotors
    Thompson Elite seatpost (cut down)
    SDG Ti-Fly seat
    Thats roughly the spec....
    Edited to say Middleburns are not an option, need to be external BB..
    Broken and dizzy
    Nice ride man! Love the stealth black! Mine's right at 38lbs. Rim and tire changes should get me down to 36-1/2 to 37lbs.
    https://i10.photobucket.com/albums/a...f/IMG_0038.jpg
    wuss
    Reputation: dropadrop's Avatar
    Quote Originally Posted by SJensen
    They are really nice if ISIS is your thang...
    moaaar shimz
    XT's then..
    dontcha?
    Reputation: captain spaulding's Avatar
    Nice, the Atherons' run XTR cranks on their dh race bikes, so I can only assume they're holding up if they trust them enough to run them on their dh bikes.. but then again, if they break a set it's not coming outtta their pockets..
    "The future belongs to those that believe in the beauty of their dreams."
    Dec 2004
    Look at WellGo MG1's if you're going to run flats...my son races with them, they usually last a season and weigh 378 grams. The Easton Flatboy's are better but heavy. I also switched out all my bolts to titanium except for the shock mount hardware and fork crown bolts.
    If you're looking for brakes, go with Formula...very very nice.
    -C-
    -C- is offline
    To be honest, the one thing I won't compromise on is the pedals, i've run Flatboys for 2 years now & they have been nothing short of superb, and they seem to be just the right size & shape for my feet.
    Formula brakes are heavier than the current XTR offereings (by quite a bit too).
    I just dont see how you guys get your bikes so light. My Socom is 39-41 depending on wheels/tires.
    Is that Bill rated?
    Reputation: Lord Humongous's Avatar
    External axles do break
    Look at my avatar, XTR 960 cranks - sheared on a trailride. Shimano took care of me and it was probably a one in a million defect, but it can happen. Just something to think about.
    Well, it was a good try.
    -C-
    -C- is offline
    Quote Originally Posted by kntr
    It's quite easy to do when you sart thinking about it.
    Based on my spec earlier, Vs your lightweight spec I saw when you got your bike I have saved 5lbs...
    The forks & wheelset alone (incl tyres) is knocking on 2.5lbs...
    Start to get really expensive though if you take it to the extreme! I reckon I could get a Socom to low 34's if I tried. Obviously it wouldn't be bombproof, but I would still have faith in its ability to take some stick...
    Dec 2004
    Socom
    Here's my current build. I will eventually be running a new wheelset, the Boxxer Team fork with a Sunline direct mount stem and Sunline bars. Maxxis DHF/DHR 2.5 with Maxxis Welter Weight tubes. The current build is exactly 38.16 pounds.
    I hope with the new parts to be another pound less.
    Socom-med-black
    Fox DHX 5.0 w/RCS titanium spring
    2005 Marz 888 RC w/ti pinch bolts and Risse flat crowns
    Funn direct mount stem w/ti bolts
    Easton carbon DH bar and seatpost, cut down
    Sella Italia Flite TT saddle
    XO rear sfifter w/direct mount to Formula K-18's, all ti bolts, 7 inch rotors.
    XO rear der
    SRAM hollow-pin chain
    E13 LG1 with 36 tooth ring
    Syncros 1.5 reducer headset-HEAVY as hell!!!
    ODI Ruffian lock on's
    Mavic 729's-DB spokes-brass nips-WTB 20mm frnt/135mm-10mm rear hub w/DT Swiss ratchet quick release.
    Maxxis DHF 2.7 ST/DHR 2.5 3C with Maxxis freeride tubes
    Crank Bros Acid 2 pedals
    Dura Ace 12-25 cassette
    Race Face Atlas cranket 170mm
    -C-
    -C- is offline
    Quote Originally Posted by BlueRidgeRider
    Socom-med-black
    XO rear der
    I can see immediately the forks will be nearly a pound alone in saving.
    I dread to think what that wheelset weighs, ditch the 729's for 721's, ditch the silly big tyres, and ditch the Maxxis heavy inner tubes & go stans no tubes. You have instantly saved yourself in the region of 1kg plus & it will completely transform the way the bike rides...
    Dec 2004
    I may give the no tubes a shot but I really think I'm at my limit on weight after these changes.
    I spend most of my summer racing and taking trips to Snowshoe WV...all we really do is bomb the downhill runs hour after hour.
    We don't really ride the skinnies or dirt jumps, so my bike has to be a bit more solid. I'd start to worry a bit If my ride was 35 pounds...parts might start to fly off!!!
    Middleburns are the best cranks ever, I've been running them for 2 years now. They are stupid light. Pretty damn stiff (I will adsmit that they arent as stiff as OCTs or saints but still) and a LIFETIME warentee against DH racing (exept the threads and splines but you are a retard if you mess thoes up)
    Pump Tracks Are Rad!!!!
    Stand back
    Reputation: dbabuser's Avatar
    -C-
    Why not i-beam post/ seat?
    A teammate of mine has a 35 lb socom (no pedals) w/ a pretty standard build...
    Golden Bike Park
    Golden Connector Trails need your support!
    -C-
    -C- is offline
    No IBeam seat/post because a cut down Thompson & Ti-Fly is lighter! (Just)
    I do think you could have a genuine 34lb Socom, and if you tried a bit harder, even sneak it into the 33lbs zone. That would be nice!
    Capricious youth...
    Reputation: Prettym1k3's Avatar
    New Gravity Lights.
    Meh.
    The Athertons use the Shimano cranks, because they are sponsored by Madison (UK Shimano distributors) They seem to have no problems with them.
    XT cranks are good, if your a Very light/smooth rider, ie around 160lbs or less.Anything over I wouldnt use them.
    I use OCTs, Super light, Super strong, and No flex at all. My bike is around 39lbs or less.
    https://www.photosled.com/data/1392/100.jpg - Thats with Michelins, probably heaviest tyres around, at 3lbs a pop.
    Ti Spring
    Totem Solo Air
    Easton EA70 bars
    Full SRAM X0
    Dura Ace cassette
    XTR M970 cranks
    E13 LG1
    E13 36T ring
    SDG Ti-Fly seat
    You are asking for trouble with thoes wheels and then some, as well they arent as light as they look. There are brass eyelits that add right around 125 grams, go with some 5.1Ds. Sapim spokes will also drop a bunch of weight in the wheels. I would also run a wider tire up front maxxis tend to run pretty narrow. A masterpeace post will save some weight as well as a tioga spyder or some other light weight saddle (the Ti fly is not the lightest)
    run, hide, it's a bike!
    Reputation: vexhex's Avatar
    ditch that heavy ass fork and you'd loose much weight - boxxer or 40 i lighter
    xpedo pedals are the lightest i've found - they work pretty well too
    a cut down i-beam is still lighter than anything else.
    nice bike - don't forget to run xc tubes if you can, or mid weight - that helps a lot
    **! I'd rather sh!t out Mark Weir than watch him pedal up a hill !**
    mud slinger
    Reputation: kona4lyf's Avatar
    Good job! .
    fsa quad b/b and fsa gravity"s here,had no hassle,no flex,with decent pedal inserts,
    "do the things you fear and the death of fear is certain"
    Reputation: The Tod Says What?!'s Avatar
    Middleburn?
    Quote Originally Posted by vexhex
    ummmm, you are flat out wrong
    The Ifly is 145 grams The Ifly post is at 230
    A sella SLR carbon is 125 grams, or something like a spider are 140 grams, With a masterpiece you are looking at 192 grams for the same claimed length and diameter.
    The totem solo air is 5.89 pounds the Boxxer WC is 6.2 pounds, I didn't check the 40 on line but I think its like 6.8. The 40 and Boxxer also use a 1 1/8 steer tube forcing you to use a heavy reducer.
    Mar 2005
    Wow the reading comprehension in this thread is up to the mtbr standard...
    The o.p is trying to build a 35# dh bike and says that atlas and xt are too ho hum and/or heavy, yet.....................
    many suggest OCTs or gravitys (light or not), or hones......
    come on people at least look up the mfg claimed weights (99% of the time lighter than actual) on these products before you post this crap.
    So...
    If you want lighter than XT (578 g for arms and spindle), XTR is about your only option. New gravity lights are close at 692 for arms and spindle....but that is about it.
    the OCT arms are not bad (550g arms only) (definately heavier than XTs) but the bb is a TANK...and ther are no other options. A complete holzfeller with bb is comparable to saints in weight.
    Only other option would be some road crank, or middleburns with a light bb (a heavy DH bb could push the total weight over that of XTs).
    -C-
    -C- is offline
    Quote Originally Posted by themontashu
    Trouble in terms of strength? There are plenty of people who run them & get a seasons use out of it. I don't expect them to last forever...
    Although this actually raises an interesting question, I have been thinking over going UST, or going XM719 rims.
    The DT rims look nice & light @ 500g, but they have a reputation of being made of cheese. Is this still the case?
    Don't want any bigger tyres, have never felt the need for tractor tyres - they just create too much drag. 2.35's survived 2 weeks of Alpine riding with no issues & thats enough for me as a test...
    Saddle - yes there are a few lighter, but the Ti-Fly has a element of (albeit small) comfort still...
    The newer 5.1s are harder, and suprisingly the spider is mad comfy
    -C-
    -C- is offline
    The 5.1's could be an option then, but the 719's are still lighter....
    Decisions decisions!
    May 2005
    There never was a problem with the 5.1Ds. The first batch of 6.1s were sort on purpose, so that DH racers wouldn't get as many pinch flats- the rim would dent instead. DT realized how dumb that was, and hardened them up.
    they are going to be within about 20 grams or so of each other, there are EYELITS that are used to hold the nipples in that are BRASS and HEAVY, mavic also happens to list the rim weight WITHOUT the eyelits.
    Help me understand this one: you say Mavicís stated weight on there rims are before eyelets are installed? For instance, Mavic states there new EN521 weight @ 540 g. Are you saying this is the rim weight before the eyelets were pressed into the rim
    Or perhaps you are referring to the special inserts that you have to add if you purchase the EN321. The EN 321 is listed as 570 gÖ however this rim is UST which forces you to use the special cups where the spoke nipple attaches. Maybe the rim weight is before the special hardware is installed?
    -> SickLines.com <-
    Reputation: mtb_biker's Avatar
    Quote Originally Posted by flyag1
    Help me understand this one: you say Mavic’s stated weight on there rims are before eyelets are installed? For instance, Mavic states there new EN521 weight @ 540 g. Are you saying this is the rim weight before the eyelets were pressed into the rim
    Or perhaps you are referring to the special inserts that you have to add if you purchase the EN321. The EN 321 is listed as 570 g… however this rim is UST which forces you to use the special cups where the spoke nipple attaches. Maybe the rim weight is before the special hardware is installed?
    Its just UST rims that need the special eyelet that isn't included in their weights. The EN 321 is not UST.
    Do you know if the EN 521 is UST? I want to buy one or the other, but don't the weight of the UST build... I can run rim tape from Stans which will decrease total build weight. I think?
    -C-
    -C- is offline
    Having done some investigations and, weighing of bits, I have worked out the following.
    Mavic UST rims are weighed minus the eyelets. So I weighed an 819 & an 823 bare rim which were 455g & 570g respectively. The eyelets weighed 45g, in the bag, with 33 (always incl a spare). So, you would need to add circa 42g to the weight of the wheel.
    When comparing an 823 to the DT 5.1, at 500g, then adding a tube (Maxxis welterweight) is circa 150g actual weight, it becomes comparable to an 823 built up
    Maxxis 2.35" ST dual ply DH tyres weigh the same as an identical model UST tyre, the Maxxis LUST are slightly lighter, which balances out using a sealant when running tubeless.
    So all in, I wouldn't save anything going for a 5.1, the only way I could save some weight is going to 819's & I would save a max of 100g per build. Not exactly the best $ per g saved
    So i'll stick with my 823's & be comfortable in the knowledge they are light & strong
    the stans yellow tape works on 5.1Ds to convert them to tubeless, its like 20 grams
    Reputation: thegromit's Avatar
    I would go with the 5.1 and stans for sure or the dt swiss tubeless kit
