light weight offset / layback seatpost?- Mtbr.com
Results 1 to 13 of 13
    Reputation: freeriderB's Avatar
    New question here. light weight offset / layback seatpost?
    besides Thomson...who makes lightweight offset posts?
    I need some room since my frame is a little small.
    I'm looking for my AM bike, so I don't want anchors.
    Posted here because I can count on some good responses!
    Reputation: psycho_sw's Avatar
    SDG I-Beam Micro Layback Seatpost
    http://www.chainreactioncycles.com/M...?ModelID=47790
    "You don't have to outrun the Bear.. just outrun your buddy"
    i-beam
    Quote Originally Posted by psycho_sw View Post
    thanks for the link.
    No experience on an I-beam system.
    Are there enough saddle choices out there?
    Offset looks good. I'll do more research on this.
    Any others you know of?
    Aug 2010
    2011 transition 250
    2009 DB scapegoat
    Glad to Be Alive
    I am running the non-offset one....Love it
    Attached Thumbnails Attached Thumbnails light weight offset / layback seatpost?-imag0009-1-.jpg
    Reputation: charvey9's Avatar
    May 2010
    Thomson Elite makes a setback version. Hard to beat on weight and quality.
    Reputation: Gman086's Avatar
    The Raceface Respond is the only post I could find with 3/4" setback and I needed all I could get:
    http://raceface.com/components/seatp...spond/respond/
    It's not Thomson light but is strong and functional.
    Have FUN!
    G MAN
    "There's two shuttles, one to the top and one to the hospital" I LOVE this place!!!
    Reputation: Duncan1104's Avatar
    I like my Crank Bros Cobalt post. It's a 20mm setback and has a really simple and easy to adjust clamp.
    thanks for the info...I'm checking out CB and Raceface now.
    I've been on Thomson for years and they're great...but just anticipating that my replacement frame may feel a tad smaller...so investigating all options.
    Reputation: monkei's Avatar
    Theres a couple Truvativ Stylo Teams in 25mm setback (~1") on Pricepoint if 20 ain't quite enough and they're pretty light
    *Edit: lemme know if anyone locates a >or=25mm setback Al post with 2-bolt clamp (all the ones I'm finding have 1-bolt, most likely because of access issue)...
    check this out, 15mm offset, smooth shape, very lightweight only 185g for 350L
    Reputation: phyco ref's Avatar
    Jun 2010
    I run I-Beam (also non offest) but have been very happy with it, no problems or issues at all. The Bel Air would be the seat if you are looking for something with a bit of cushion and if you want sometime more light weight go with the I-Fly. I have the I-Fly on my V10, but I think I may get the Bel Air for my trail bike. I also have the Formula FX Ti on my trail bike at the moment with a dropper post and I found the Bel Air that I used to have more comfortable. Overall VERY pleased with the I-Beam products!
    Glad to Be Alive
    I am rocking an I-beam,,,,pretty lite too
  1. Seatpost Tech Question: 10mm offset = 10 degree layback?
    By chumbox in forum General Discussion
    Last Post: 02-08-2009, 07:20 PM
  2. 27.2 Light Layback Seatpost Options?
    By Axis II in forum Weight Weenies
    Last Post: 03-07-2007, 09:34 AM
  3. nino, light seatpost that is offset
    By peabody in forum Weight Weenies
    Last Post: 10-21-2005, 09:45 AM
  4. Replies: 5
    Last Post: 01-13-2005, 10:14 PM
  5. How much offset on a Thomson Layback post?
    By wfl3 in forum General Discussion
    Last Post: 02-10-2004, 07:08 AM
