Light DH bikes faster than heavy DH bikes?- Mtbr.com
Results 1 to 31 of 31
    Reputation: aliikane's Avatar
    Just curious for anybody who has a V10 carbon or equivalent DH bike in terms of weight. I was looking at the new SC V10 carbon and it is very light at around 36-37 lbs. It seems like the bike being that light will be very agile and flickable but would the stability get compromised by the lightness? When it gets rough and technical seems like the light DH bike will get jocked around a lot. I don't have a light DH bike so I don't know.
    Are the lighter bikes faster than heavier bikes?
    Locs on Spokez
    Reputation: Iggz's Avatar
    Nov 2006
    Light bikes are more intended for a float-over-trail riding style whereas heavy bikes are more inclined for the plow-over-**** method. If you're at the level where you're floating over stuff then stability isn't compromised and is totally in your control.....
    Ground Steeze. @iggy_strbac
    Reputation: his dudeness's Avatar
    Like he said... If you ride smooth and float over stuff easily then a lighter bike will be suited well for you. If you ride less smooth and generally plow through things then a heavier bike (ie-heavier and more durable parts) is what might suit you better. Weight doesn't necesarily dictate stability whereas wheelbase, geometry, and center of gravity have a bit more of an effect.
    The arsonist has oddly shaped feet!
    Professional Troll
    Reputation: Gemini2k05's Avatar
    Apr 2005
    Ceteris Paribus, a lighter DH bike is always better (well, at least at today's weights, I dunno how I'd feel about a 10lb bike even if it was indestructible)
    Reputation: Calles's Avatar
    May 2010
    Quote Originally Posted by Gemini2k05
    Economics major?
    "Some people think they can outsmart me... Maybe... I've yet to meet one that can outsmart BULLET."
    -Heavy
    Professional Troll
    Apr 2005
    Quote Originally Posted by Calles
    Economics major?
    good call
    light bikes are great until you break them or parts. then you need heavier stuff. go as light as you can reasonably afford.
    May The Force Be With You
    Reputation: shwinn8's Avatar
    Feb 2006
    i would think it depends on the riders skills & strength
    '16 Balance
    '11 Jedi
    '08 Toyota FJ Cruiser / Facebook: NyNomadFJC
    bike rider
    Reputation: Lelandjt's Avatar
    My V10 is currently 37lbs and is faster than when it was 42lbs. I don't notice any negative traits and wish it was 2-4lbs lighter.
    Keep the Country country.
    Heavy DH bikes deflect less.
    PoisonDogFart
    Reputation: bullcrew's Avatar
    Jan 2005
    Quote Originally Posted by blumarvel
    Agread...
    Your only as fast as the first broken part on the bike...So if it holds then you finish if it doesnt then you DNF. So style/weight go hand in hand and the lighter the bike the more possability for a DNF.
    My Sponsor House
    "I dont make memories, I make History."
    CANFIELD - AVALANCHE SUSPENSION - SCHWALBE - TLD
    bike rider
    A lighter bike can be "caught" and brought back on line quicker. When my dirtbike deflects I have to let off and put a lot of effort into catching it. I barely notice when my DH bike deflects.
    Reputation: Quarashi's Avatar
    Disagree.
    I think suspension set up, handlebar width, frame, wheel and fork stiffness and geometry will have a much more realistic effect on deflection. Especially considering how much a person weighs relative to the bike.
    I don't think it's how light bikes are literally but how light they ride. I have a Banshee Scythe right now that weighs about 38lbs and I have friend who has an old glory that's pushing mid 40's. His bike was easier to "float". My lighter bike actually likes to plow more and holds a straight line better.
    5 pounds on a bike will make a huge difference but I don't think that's what makes a bike "skitterish".
    About buying a bike:
    Quote Originally Posted by No MSG
    It's like finding a wife. Personality is important, but you gotta look at that face every morning.
    How much does your dirt bike weigh vs. a heavy DH bicycle?
    PoisonDogFart
    Quote Originally Posted by Quarashi
    Disagree.
    "For every action there's an equal and opposite reaction" But yes, I agree that suspension plays a huge factor. That only makes sense.
    PoisonDogFart
    bike rider
    More. The point is that while extra weight resists deflecting, it also makes it harder to correct a deflection.
    On a heavier bike it's also harder to make a quick, last moment adjustment to dodge a rock so you'll get more impacts/deflection.
    If everyone had a chance to ride a 36lb DH bike that didn't have durability issues questions like this wouldn't be asked.
    Im a Cowboy
    Reputation: CrustyOne's Avatar
    Oct 2007
    agree with most allready said
    But its not how it reacts to terrain that is an effect...............
    A heavier bike has more potential energy when taken to the same spot up a hill, (basic physics, it took more energy to get the bike up there...it has more enrgy to release on the way down)
    A heavier bike CAN be an advantage as it less prone to slow down as it has more inertia, BUT is harder to accelerate if you let it slow down
    I tried a light bike 2 seasons ago (intense), it flexed so bad i never got to trust what it would do in the gnar (im only about 170 lbs, cant comment on my flowiness of lack of it)
    DON'T TELL ME I'M STILL ON THAT FECKIN' ISLAND! ....
    The whole industry is moving toward lighter DH bikes. So, there must be something to the lighter bikes that some of the pros are wanting. I don't have a full DH bike yet. I have a SS and 6.6. They weigh about 1.5 lbs apart. The SS is more stable at fast speeds through rough technical sections and the 6.6 is just more flickable and a better jumper, but gets deflected more in the rough technical.
    I would like to see chart of the top 20 DH pros and weights of their bikes.
    I guess a lot depends on the course. Some just more straight flat out bomb courses a heavier bike may be better and the tighter twisty courses a lighter bike may be the ticket. I would like to see someone racing a tank of bike like 50lbs.
    Executive User - UK
    Nov 2008
    Quote Originally Posted by aliikane
    There was a video a few months back showing weights of pros bikes.....worth a look.
    Quote Originally Posted by CrustyOne
    There is too much going on to toss it up to basic physics. At the end of the day it's the quality of the parts that make a bike carry through the rough well. Technology these days is quite amazing in that you actually can make a 36 pound DH bike without compromising strength and stiffness.
    Practically speaking from experience, the biggest factors in reducing defflection are:
    A stiff fork ( I love 20mm thru axles long time! ) - Most important IMO.
    Slack head angle
    Rear ward axle path
    Wide bars
    Stiff frame
    If you feel like a lighter frame is making the frame deflect then you can compensate by reducing the spring rate or changing the damping.
    I think an often used example for light bikes and being skitterish is the Session. I'm 90% sure that it's mostly the leverage curve that makes that bike so "bouncy". My Scythe has it's pivot in a almost the exact same spot and it feels polar opposite to the Trek.
    bike rider
    I would like to see a chart of the top 20 DH pros and the weights of their bikes.
    The mentioned video showed them all being 37-39lbs. However, top pros are limited in parts selection due to sponsorship. They don't have the freedom to buy the lightest, strong parts. Look at every top WC bike and there's a couple parts I'd swap to something lighter but equally performing.
    Im a Cowboy
    Oct 2007
    Hmm, not convinced, maybe they just possibly dont want a sub 37lb downhill bike, I know from personal experience that it wouldnt suit me
    One other thing I notice a lot is people on here often quote a bike weight that is pure BS.
    Like its some sort of competition to say your bike is < Xlbs
    Ho hum, think ill go ride my 40lb tank down a hill
    Glad to Be Alive
    lighter bike faster accelaration, easier to move around just seems quiker...heavier bikes feel sluggish
    My opinion...you can build a 38 pound dh bike and it still hold up to a pounding
    Reputation: Pwshadow's Avatar
    A heavier dh bike will be faster if you drop both out of an airplane Higher terminal velocity.
    meow meow
    Reputation: b-kul's Avatar
    Quote Originally Posted by Pwshadow
    if we use two identicle bikes but one has a solid frame. cant discount drag.
    Quote Originally Posted by b-kul
    Of course. In this senario a sleak aero-dynamic frame like a santa cruz v10 would definitely beat a demo 8. that bulky rear end would just cause too much drag.
    Quote Originally Posted by Lelandjt
    I think most of those guys could go for a part or two off of their regular sponsors offerings if they really wanted to. I mean look at all the guys running blacked out Minions or High Rollers.
    True. A bet a lot of it is spreadsheet weight.
    I recently weighed my decently built 7x7 bike that I would think to about 36-37lbs. Turned out to 40. No idea why it's so heavy. I shouldn't have weighed it. It would have still weighed 36lbs if I didn't put on that scale.
    meow meow
    if you drop anything out of an airplane at its cruising altitude drag plays a very signifigent role. physics 101 dude.
    bike rider
    Quote Originally Posted by jcook1989
    They can get away with that cuz tires aren't as obvious. A Shimano sponsored rider can't get away with running Formula The Ones, even though they'd drop 1/2 a pound from his bike.
    Im a Cowboy
    Oct 2007
    Oh good grief
