Kona Bearing Help- Mtbr.com
Results 1 to 11 of 11
    Feb 2005
    New question here. Kona Bearing Help
    Hey All,
    I need help tracking down the bearings for KONA frames. I have had a lot of people ask me to get them bearing kits for KONAs but I don't know what bearings they need. KONA won't tell me cause they like to sell their kits for $100. I know some of the bearings and know I can put one together for under $40.
    So if anyone know what bearings and how many any dual suspension Kona frame uses I would really appreciate your help in identifying these bearings. If you have a KONA and want to help me I will give you 50% off a full bearing kit for your bike!
    Thanks for you help!
    I liked the old *****
    One URL/site I saved: http://www.abiindustries.com/enduro/index.html I haven't had to replace bearings yet, so not sure about details . . . but would imagine all you need to do is read the number on side of bearing.
    Feb 2005
    Thanks Perogative but I don't have a Kona to check the bearings against. I sell bearing kits for full suspension bikes, and hubs. I actually sell ABI Enduro bearings but unless you know the part number and quantity I can't put together a bearing kit. Thanks for the help though.
    Who pickin the banjo?
    Reputation: menachite's Avatar
    Do you sell bearing kits for any other bikes? Got a website?
    "We ought never to look behind us with regret nor ahead with fear, but around us with awareness."
    Reputation: GOLLUM's Avatar
    Mar 2005
    Try www.bikebench.com
    Quote Originally Posted by MrFurly
    Hey All,
    the web site has bearing replacements for all sorts of frames and components. Check it out.
    RESIST OR SERVE!!!
    Sorry - wasn't near my bike, now I am:
    Main pivot x2: "6001 2RS"
    Rear pivot x2: "608RS" (same as "608 2RS" on web site?)
    Both are Enduro as expected, and on 03' Stinky P
    Don't plan on taking apart swingarm, but will look around to see if I can find out what it is.
    Regards,
    Glad to Be Alive
    If you ride in pretty much dry conditions...How often do you need to change the bearings. My Big Hit had 3 years without bearing replacement
    Feb 2005
    Some people change their bearings every season but 2-3 years is normal bearing life. The problem is usually the grease inside breaks down and then your bearings start to scrape and sieze. If you suspension pivots are stiff and making a lot of noise chances are you need new bearings
    I sell bearings for a lot frames and probably have bearings for frames I don't know about. Check out my websiteBiker Bolts and Bearings
    Thanks a lot Perogative, those were the ones I knew about I would imagine the ones in the chainstays are 608s as well but I dont want to put a kit together without knowing for sure. Again thanks for your help!
    the bottom seatstay pivot uses bushings instead of bearings.
    NorCal slum bum
    Reputation: captainpolution's Avatar
    Quote Originally Posted by wgcviii
    word
    yo mrfurly, you should start carrying igus bushings. but i guess it would be too hard since there are so many
    Feb 2005
    I have been thinking about it but man there are so many and I am having enough trouble figuring out bearings. Once I have put together some more bearing kits I will start to focus on bushings.
    Quote Originally Posted by captainpolution
    word
  1. Need help in restoring an old Ti Kona
    By fishy in forum Kona
    Last Post: 12-04-2005, 07:47 AM
  2. Ordered an 05 Kona Shred for Urban...
    By Norco in forum Downhill - Freeride
    Last Post: 07-06-2005, 08:29 AM
  3. Frustrated with Kona LBS
    By BAlGaInTl in forum Kona
    Last Post: 07-07-2004, 10:24 PM
  4. WTB/amclassic disk hubs..
    By bike_freak in forum Weight Weenies
    Last Post: 02-05-2004, 06:30 AM
  5. Kona Official Supplier of Whistler Mountain Bike Park
    By CraigH in forum Downhill - Freeride
    Last Post: 01-29-2004, 08:00 PM
