Knolly Delerium and a Boxxer ???- Mtbr.com
Results 1 to 7 of 7
    Has anyone mounted a Boxxer on a Delerium T???
    The axle to crown of the Boxxer Team is the same as my 66ATA that I currently have mounted on the frame.
    I'm thinking of racing a couple of local DH's this summer, so I'm primarily after the superior dampening that the Boxxer has over the ATA. I'm not looking at it to hit any larger drops.
    Thoughts? Opinions? Other options?
    I'm running a DHX 5.0 with an upgraded 09 piston and the pro-pedal de-tuned. I'm about 170 pounds fully geared up.
    Bike Ninja |||
    Reputation: chooofoojoo's Avatar
    Feb 2007
    Do it. if the a2c is the same then:
    1) you're geometry won't change
    2) you'll get an extra 20 mm or so of travel with the same a2c
    3) you're bike will look far better
    4) you're wallet will be severely lighter.
    Proud to represent Mojo Wheels.
    Seeeriously easy Livin
    Reputation: Flystagg's Avatar
    Nov 2006
    just be sure to set the boxxer to 178mm
    Citizen Of Earth
    178.314
    "If your not living on the edge, you're taking up too much space." ~ J. Whittaker
    Roll on Spring Time!
    Reputation: juan pablo's Avatar
    Just remember to post picks and ride report or dont come back!
    Capricious youth...
    Reputation: Prettym1k3's Avatar
    I've seen DT's mostly with 36's and Totems. I'd stick with that, but that's just me.
    Meh.
    e.f.f.e.c.t smoothoperatr
    Reputation: themarsvolta55's Avatar
    Dec 2004
    Quote Originally Posted by xterrain
    178.314
    really?
