kicker question for WCH- Mtbr.com
Results 1 to 5 of 5
    dirtbag
    how do u determine the amount of curve in your ramp? i'm trying to build a kicker but i can't figure out how to draw/cut a smooth curve into the plywood sides.
    I have a dk legacy bmx bike for sale if anyone is interested. email me at c_happ9000@yahoo.com
    ridin' the hope
    Reputation: Grantels's Avatar
    Use a peice of string like a big compass.
    lay your sheet of ply on the ground. tie one end of the string around a pencile and the other around a screw driver. jam the screw driver into the ground.use the pencile to draw your tranny/lip. this is the method i used to biuld my mini rsmp for skating. we used a 7ft radius for a four ft tall ramp. so for bikes on a 4x8 sheet you may want to try like a nine to ten foot radius. play around with it before you cut. good luck.
    dirtbag
    thanks that helps a bunch. i'll try it tomarrow and hopefully post pics of the ramp soon.
    Pro Crastinator
    Reputation: .WestCoastHucker.'s Avatar
    i used an 8' radius
    USB Rep'n
    Reputation: namaSSte's Avatar
    we generally use 9' too...
    Quote Originally Posted by zachdank
    i used a 9' radius
    a 4' high kicker with a 9' radius will launch you plenty high. playas like WCH can do that 8' thingy better than I so it really depends on your ability level imo.
    though hope is frail, it must prevail - Taj Weekes
    betam eh-wud-eh-HA-lehu y
    eh-nay Ityopia!
  1. Racer-X build question or two........
    By 2ManyMoots in forum Titus
    Last Post: 08-09-2005, 05:24 PM
  2. front suspension question
    By dan burnham in forum Beginner's Corner
    Last Post: 09-23-2004, 02:34 PM
  3. Brake response question? and Slider pressure question?
    By Gnar in forum Downhill - Freeride
    Last Post: 09-05-2004, 03:20 PM
  4. Newbie Lbs question
    By joshua_msu in forum Riding Passion
    Last Post: 03-15-2004, 10:13 AM
