Ironhose 7.3, weight loss.- Mtbr.com
Results 1 to 11 of 11
    So im really thinking about getting myself a ironhorse 7point3. But the weight is ridiculous, well not that ridiculous bu if i am to get one i would like to bring the weight down. So this the setup, if you guys could just point out some places where i could really shave some weight that would be great.
    REAR SHOCK :FOX VAN R COiL, 8.75X2.75
    FORK :MARZOCCHISUPER T RV, 185MM TRAVEL
    HANDLEBAR: FUnn 318, 30MM RiSE, 710MM widTH, 31.8MM CLAMP
    STEM: FUnn MZX4 diRECT MOUnT STEM, 31.8MM CLAMP
    HEADSET: FSA ORBiT Z 1.5 R
    BB: FSA MEGAEXO, 83MM
    CRANK: FSA GRAViTY MOTO X, 170MM
    RINGS: FSA BASHGUARd/36/22T STEEL
    PEDALS: WELLGO B66 PLATFORMS
    CHAIN: SRAM PG-951 w/ POwERLink
    SADDLE; SDG BEL AiR ST i-BEAM
    SEATPOST: SdG 6061 BEAM, 30.0MM
    F. HUB; ALLOY DH, SEALED BEARinG THRU AXLE, 32H
    R. HUB; ALLOY SEALED BEARinG THRU AXLE, 32H
    F. DER: SHiMAnO SAinT, 34.9MM CLAMP
    R. DER: SRAM X.7 Mid CAGE
    SHIFTER: SRAM SX.5 TRIGGER
    CASSETTE: SRAM PG-950, 11/34T, 9 SPEED
    BRAKES; AVid JUiCY 3 8 ROTOR
    BRAKE LEVER: AVid JUiCY 3
    RIM; SUNRIMS MTX S-TYPE
    SPOKE: dT/SwiSS CHAMPiOn 2.0
    TIRES: MAXXiS MiniOn F dH 3C COMPOUnd, 2.5 FRONT/2.5 REAR
    WEIGHT: 41.6Lbs /8.7kg
    moaaar shimz
    Reputation: tacubaya's Avatar
    41 lbs is 8.7 kg? wow that bike is light in metric units
    Reputation: mace2's Avatar
    clearly missed a 1... it's 18.7kg
    to be honest, to drop a noticeable amount of weight it'll probably cost you a fair bit... if you want a lighter bike then buy something lighter to begin with. just imo.
    N* Bomber Crew
    Reputation: Raptordude's Avatar
    Tubeless might help, other then that I'm not really sure if theres a cheap thing on that bike we can scrap for weight.
    Northstar 2008 Riding Crew
    Reputation: ikilledkenny2's Avatar
    Every where
    Trek T1 . MOJO SL 2011 Fox 32 Talas 1X10 FTW
    EastBaySteez
    Reputation: Freerydejunky's Avatar
    41, I have mine right now at 39, are you running DH tubes? if so take them out. Weight isnt a factor, just ride money get your legs stronger.
    Gamut
    Team Evil
    Formerly: motormonkeyr6
    stop being a *****, my xc bike weighs more than my v10
    Glad to Be Alive
    get a ti spring and it will weigh 41
    EastBaySteez
    Quote Originally Posted by SJensen
    Thats how we roll
    Gamut
    Team Evil
    Premium Member
    Reputation: Ojai Bicyclist's Avatar
    Look, I'm a caveman, I'm tuff and manly!
    Te mortuo heres tibi sim?
    Quote Originally Posted by thecrazyfrenchman
    REAR SHOCK :FOX VAN R COiL, 8.75X2.75 swap to a ti spring, or on of the newer larger volume air shocks?
    RINGS: FSA BASHGUARd/36/22T STEEL swap to alu rings when these wear out
    TIRES: MAXXiS MiniOn F dH 3C COMPOUnd, 2.5 FRONT/2.5 REAR lighter non-dh tire up front? ditch dh tubes if they are in there
    otherwise, save up for some lighter wheels or lighter fork. you'll notice the most difference with lighter wheels. lighter doesn't always mean weaker. the stock hubs are probably boat anchors.
    otherwise, ride it as it is. when something wears out or breaks, replace it with something a little nicer/lighter. it'll evolve into a lighter and nicer bike over time.
