Intense m1 rear wheel help- Mtbr.com
Results 1 to 9 of 9
    Moose Member
    Reputation: Moosey's Avatar
    May 2010
    So the rear wheel on my intense m1 is obviously off center. I have the big black cone like spacer inbetween the sides of the rear triangle and thats it. It really seems like im missing a spacer, but if i am i dont know where it went. can someone post a picture or something of the rear axel on a 2002-2003 m1? it would be really appreciated.
    Moose Member
    May 2010
    Heres one side og my axel, should it be stickin gout that much?
    Heres the other side...
    My only thought is that the spacer on the outside should go inside. i have no idea though. Is there a place to got replacement spacers or any sort of spacer that would work?
    Im a Cowboy
    Reputation: CrustyOne's Avatar
    Oct 2007
    What makes you think its the hub thats out and not just the rim?
    1. Is your chain line spot on?.....
    2 .Is the brake aligned ok without being at the extreme of lateral adjustment range or using non-standard spacers/washers?
    if answer to 1 and 2 is yes, then its your rim thats out
    DON'T TELL ME I'M STILL ON THAT FECKIN' ISLAND! ....
    Reputation: kdiff's Avatar
    I think it looks fine. Here are some pics of mine.
    How's the Avy?
    Glad to Be Alive
    Quote Originally Posted by CrustyOne
    man that looks right to me....looks like brake rotor lines up too....think it is your rim there brother
    Moose Member
    May 2010
    Alright. I only asked this because my tire is closer to hitting the left side of my rear triangle, and there is much more room on the right.
    Thanks for all the help
    Slap happy crappiness
    Reputation: DHgnaR's Avatar
    Take it to a shop and have them properly dish your wheel.
    I'd rather have a bottle in front of me than a frontal lobotomy.
    meow meow
    Reputation: b-kul's Avatar
    Quote Originally Posted by DHgnaR
    yep, disc is alligned nicely, your wheel needs to be dished.
    Glad to Be Alive
    fyi
    dish is where, when building wheels, you offset the middle line of the rim...was done a lot on 135mm rear spacing rims
