installing boxxer. need a bottom pressfit/adapter or cup?- Mtbr.com
Results 1 to 8 of 8
    Come at me bro.
    Reputation: drastic.'s Avatar
    removed my domain, and there was a pressfit on top of the crown which the lower headset bearing sat on:
    went to install my boxxer, and there was no pressfit on top of the crown. the bearing sits on the crown w/ some 'play' on it.
    it seems it doesnt take much tightening of the bolt on the stem before there is friction on turning the bars..
    is there a fitting or headset adapter piece/cup that i need to install for the bottom bearing to sit on?
    fwiw, im running a FSA Orbit-E-1.5R headset.
    powered by bacon
    Reputation: helidave's Avatar
    you need to take that crown race off your old fork and put it on the boxxer. look on youtube for a how-to
    Come at me bro.
    Quote Originally Posted by helidave View Post
    if you mean, put that piece onto my boxxer crown..it's a pressfit. no way to get it off. maybe my LBS have some which they can install?
    powered by bacon
    they are pressed on but not that tight.
    Thursday Tech Tip - YouTube
    to install it you can use any piece of tube with the right inside diameter and a hammer. I use an extension tube from a vacuum to set mine.
    Come at me bro.
    + repped.
    thanks. i tried fitting a flatthead in the little divot and twisting prior to seeing this link. ended up chipping it very slightly. since i sold the fork to someone else, and am shipping it tomorrow, i didn't want to scuff the crown or damage that piece any more.
    atleast i know the proper way now. I see FSA has a crown race specific to the headset, but is there pretty much a generic/universal piece that a LBS will have that works?
    thanks for the help.
    powered by bacon
    headset specific, comes with the headset
    Come at me bro.
    well, this thread was quick and easy.
    thanks again for the help. ill just order the piece now.
    if you could, id order a new headset. having sealed bearings is a major plus!
  1. Installing Boxxer on santacruz bullit
    By chriscorv5 in forum Shocks and Suspension
    Last Post: 08-27-2010, 01:26 PM
  2. PressFit 30 Bottom Bracket Unavailable?
    By DekerfTeamST in forum SRAM
    Last Post: 11-22-2009, 08:09 PM
  3. Boxxer Adapter
    By Phierce in forum Shocks and Suspension
    Last Post: 11-11-2008, 07:47 AM
  4. Boxxer to 40...adapter?
    By OB1 in forum Brake Time
    Last Post: 10-19-2007, 09:53 AM
  5. Which Hayes adapter for '07 Boxxer...
    By bpnic in forum Downhill - Freeride
    Last Post: 03-11-2007, 09:55 AM
