I need help with my 08 Boxxer WC- Mtbr.com
    I figured that I would try here before the suspension forum.
    The last few rides of last year I noticed some oil coming out from under and around the blue compression nob and now I noticed that the fork has little to no rebound damping.
    I did some research and found what I thought was a "fix" but after some more searching that "fix" does not really work and most people suggest getting a new cartridge.
    I guess I'm looking for some solid advice from people that have had a similar problem and what i should do to get my fork back to normal or better.
    Oct 2007
    when was your last full rebuild? oil and seal replacement...
    my 06 team did the same thing, new seals and oil did the trick.
    That was my intention.....
    to have a complete rebuild done.
    I was just unsure if anything can be done with the cartridge.
    Oct 2007
    its likely theres nothing wrong with your cartridge. just some bad seals.
