How to stop mother f****** chain slap!!!!!????- Mtbr.com
Results 1 to 46 of 46
    Teh Original Dirt Muffin
    What are some good ways to stop chain slap??? I am planning on getting a chain guide, and I heard that helps, but what are some other ways to tighten that thing down so it doesn't move make so much dang noise? I got my derailleur chain tension screw on max and the chain shortened by 1 link. The other day I was riding down stairs and it sounded like my whole rear end was about to fall off! This is one problem I hope they resolve in the future of DH/FR mountain biking cause it is just plain annoying!!!!!! Bang, BANG, BaNG, BAng. I am on borderline psychosis from da** chain slap!!
    Thanks, Shredder111
    Jun 2005
    Chain guide will help, and will give you more confidence in pedalling through rock gardens. Also I found that using a road or super short rear derailleur and a close ratio cassette makes a huge difference. It will also raise the whole drivechain up increasing rock clearance. You can also take a couple of links out of the chain.
    Best
    Florida Rider
    Reputation: atomrcrkhsbiker's Avatar
    not much you can do, I would pad the chainstay so that 1) It doesn't get damaged and 2) it will quiet the sound of the chain hitting your bike significantly
    -> SickLines.com <-
    Reputation: mtb_biker's Avatar
    Chain guide,
    smaller cassette in the rear (road cassette) (lets you run a tighter chain)
    shorter chain
    short cage rear derailleur (or road derailleur)
    Schmeow Productions
    Reputation: JBsoxB's Avatar
    not sure if you want to do this, but sram derailleurs are tighter, or you could get an internal hub (rollhof or however you spell it) w/ a rennen tensioner...
    Reputation: DHFreak's Avatar
    You should take your chain off....that would be SUPER HARDCORE
    Retread soul rider
    Dec 2005
    On one extreme, high pivot single-pivot suspension designs often have no slap at all... and singlespeed hardtails cannot have any.
    You may be hearing your rear-d slapping the chainstay (BigHits are known for this and mine does it) so pad the area where it would/could hit.
    Juanjo
    Reputation: EastCoastHucker's Avatar
    Jun 2005
    Just go SS (single speed)
    ~~~~~~~~~~~~~~~~~~ \m/>-<\m/ ~~~~~~~~~~~~~~~~
    Jesus loves you ............. Everyone else thinks your an A$$hole .
    Mar 2005
    tape it
    I found that the sound doesn't bother me like the paint chips in my frame. The sound informs me that I'm riding at an appropriate pace. I just wrap the piece the chain slaps with some electric tape. Couple bucks on a roll of tape and your set down the road.
    wishiwereridingmybike
    Reputation: #1 Hucker's Avatar
    If you have a front der the chain is probably making noise slapping that too.
    SXtreem now
    Reputation: RMXtreem's Avatar
    buy a SRAM!
    Meh.
    Reputation: XSL_WiLL's Avatar
    You can set the spring tension to the higher position. Helps drastically, and improves shifts.
    Otherwise. Buy SRAM, get a good chainguide.
    Jan 2005
    Like a lot of the others said, Sram, chain guide pull a link and wrap the chainstay with a tube.
    Reputation: Tarekith's Avatar
    Mar 2005
    Yeah, almost 100% of my noise is from the FD. Not much I can do about it...
    Tarekith.com
    '17 Specialized Enduro Elite 29
    set your chain length correctly, and you shouldnt get chain slap.
    "What would happen to the Weather Channel's ratings if people werent scared anymore?"
    Hell from above
    Reputation: kornhole's Avatar
    Mar 2006
    Use a i pod.
    Oct 2007
    I am running a xt rear der and have experienced a lot of chain slap. Can I run a SRAM rear der with my current shimano shifters?
    Locs on Spokez
    Reputation: Iggz's Avatar
    Nov 2006
    Nein. Sram = Sram shifters.
    Ground Steeze. @iggy_strbac
    Glad to Be Alive
    take shock have bike....compress rear suspension......cut chain after having it in biggest coggs....leave a little for measurment error
    Freetard.
    Reputation: Nut!'s Avatar
    Nov 2007
    Old tube + electrical tape: wrap around the chainstays and your done.
    Quote Originally Posted by Khemical
    Those cables on the Socom look flexy
    Slap happy crappiness
    Reputation: DHgnaR's Avatar
    Quote Originally Posted by Zonk0u
    Proper chain length will reduce chain slap, but usually not completely eliminate it.
    I'd rather have a bottle in front of me than a frontal lobotomy.
    what are you using for a chain stay protector. If its on metal, its gonna be alot louder (and possibly damage your frame) so using an old tube to wrap it, or my favorite wrapping it in road bar tape will quiet it alot.
    Chain guide entirely solved my issue with slap. I haven't had any since and I have been very happy
    check your six
    Reputation: sodak's Avatar
    Quote Originally Posted by MonkeyBidnezz
    Exactly!!
    "We can always find excuses if we want to find them, but if we really want to do something, we have to just go."
    The Beaver
    Reputation: Mwehahaha's Avatar
    like said before the big hits are really bad for the rear der hitting the chainstay... you will always have noise coming from back there though.
    Just ride fast than the speed of sound and you will be fine.
    Specialized P.1
    Specialized Demo
    Reputation: norbar's Avatar
    Quote Originally Posted by ilikemybike011
    What's wrong with sram shifters? I use their triggers integrated with my formulas and they work great. No trouble with x-9 trigger to x-0 and 9.0sl so don't know what's the problem with them. Sram simply rocks.
    BTW. Is that true that Road Sram Derail needs special Road Sram Shifters? Cuz I'm thinking on getting myself one(156g !!)
    www.totalbikes.pl - Bike Camps not only in Poland
    dosnt chng titls...o wait
    Quote Originally Posted by mtb_biker
    Chain guide,
    shorter chain
    what?
    how would a smaller gear making the chain shorter? it would make it longer cause the gear takes up less links, and those are added to the slack.
    tubes hate me
    Meh.
    Quote Originally Posted by yoboe
    what?
    No... it lets you run less chain... you size the chain based on the road cassette. You can use less total links... in addition, with a 11-34 cassette, you have a much larger gap between gears, this means that the derailleur needs to take up more slack in the smaller gears. With a 12-26, it's a much smaller gap. So less chain is required and the derailleur doesn't have to take up as much slack.
    Think about it.
    Somebody had asked if they could run Shimano shifters with SRAM derailleurs... he was saying no, you have to use the 1:1 SRAM shifters with SRAM rear derailleurs.
    Yes, SRAM road derailleurs need different shifters, the pull ratio is different.
    oh i see what you mean now about the casset
    tubes hate me
    Locs on Spokez
    Nov 2006
    Quote Originally Posted by norbar
    Read better. He asked if he could use a Shimano shifter with a Sram deraileur, I said no.
    StraightOuttaCompton
    Reputation: Djponee's Avatar
    ride chainless.
    HARDTAIL PRIDE- 09 Kona Five-0
    Commit or eat sh!t
    Reputation: Cable0guy's Avatar
    Get a chain guide and get back to us if that doesn't work. You can't really do DH/FR without one.
    If you have deep-pockets, consider "shrink tubing". You can probably get it from an automotive-specialty shop. . . friend of mine did this to the drive-side chainstay and seatstay of his Nomad. No noise from chainslap, definitely low-key "bling-bling" and it doesn't leave a residue or adhesive coating on the frame.
    If you have nothing but pocket-lint, consider old inner-tubes. You can probably get it from the dumpster behind the LBS. . . I did this to the drive-side chainstay on my Huffy. No noise from chainslap, definitely "ghetto" and. . . whatever, you get the picture.
    old broken downhiller
    Reputation: Big Mike's Avatar
    I don't know how many Big Hits I've seen with either a piece of tire zip-tied to the stay or an old Judy elastomer split in half and zip-tied to the derailleur knuckle. Those things make a racket.
    If you care about how it looks - road bike bar tape. Pick a cool color and wrap it up.
    If you could care less how it looks - electrical tape and an old inner tube.
    The I-pod idea is good too...
    Refusing to grow up since 1978...
    respect the wildlife
    Reputation: BillyBob's Avatar
    Chain guide. Blackspire Stinger is 25 bucks, problem solved.
    http://www.pricepoint.com/detail/152...hain-Guide.htm
    It's carbon dontcha know.
    Reputation: 6thElement's Avatar
    from 0 - sideways 3.2 sec
    Reputation: derekr's Avatar
    Use the soft fluffy side of sticky back velcro and attach everywhere that the chain can hit, also if your cables are near by you can cover them in tubing, check out this months dirt it explains how Sam Hill silences his ride and apparently its VERY silent, gona give it a go i hate chain slap.
    Reputation: ridingsupreme's Avatar
    wrap an old tube around your swing arm, and in places you may or may not be able to do so get some duck tape and layer it on there. should annihilate your problems without changing a single part on your bike. but then again crappy bikes are just loud no matter what you do... take intenses' for example... even kovariks bike struggles to comply with acceptable noise decibel levels lol
    Reputation: CBiDrive's Avatar
    I am a big fan of the tube wrap on chainstay.
    At least hikers can hear you coming
    SingletrackMind
    Nov 2007
    You could use some F-4 tape.
    Riding with...
    Reputation: KevinM[Freerider]'s Avatar
    Aug 2005
    First of all...I would only suggest putting duct tape on your bike if you are either A. A dumbass or B. dont care about your bike. Duct tape is just going to leave a bunch of sticky crap left on your frame after the chain eats away at it, have fun selling
    Heres how my faith is done. I have it a little more trimmed up now though. I did this after seeing the sunday done up like this.
    Quote Originally Posted by Tarekith
    Isn't the proper etiquette on this forum to wait until he posts a picture of himself dropping it, and then spend 70 posts arguing about how big it is? I mean, let's not jump the gun, without a pic of his bike in the air, we can't have photoshopped triagulations and geometrical equations showing why it's really 2 feet and not 22 feet.
    "Quick, pass the bike up again so i can hit it before it starts to hurt!!"
    AIM: Haroracer842
    Jul 2018
    This works sooo well!!
    https://youtu.be/L1t3UzjveQk
    BOOM goes the dynamite!
    Reputation: noapathy's Avatar
    Quote Originally Posted by mtbbeta View Post
    10 year old thread revived for an affiliate linked video telling us to put 3m mastik tape on the chainstay. Fail.
    :nono: :thumbsup:
    Glad to Be Alive
    Quote Originally Posted by noapathy View Post
    agree
    West Chester, PA
    It's damn funny though. Wasn't so long ago that we didn't have clutch derailleurs and NW rings. Used to run a stinger AND a mrp top guide on my first 1x setup. Now don't need either.
    Reputation: ALimon's Avatar
    Oct 2017
    Ride chainless ....... it seemed to work well for Gwin.
Members who have read this thread: 22
