How much PSI ?- Mtbr.com
Results 1 to 7 of 7
Thread: How much PSI ?
    Portland, OR
    Reputation: todd_freeride's Avatar
    Aug 2005
    How much PSI ?
    hi all, I was just wondering, how much psi are you running on your DC fork ? and for what type of riding ? I ask because I've always had my forks super stiff. because of short travel and harsher riding, but reciently I got a 170mm travel fork for my hardtail. what amount of psi should I run for downhill, how much for freeride ?. I like my forks a little plush so they'll still soak up the bumps. how much psi are you running ?
    Ibex bikes
    2007 Ibex Trophy SS
    2006 Jamis Komodo 3.0
    2006 Ibex Zone FR-1
    2004 Special-Ed P.2 A.1
    Reputation: shiggy's Avatar
    Dec 1998
    Depends on the fork, your weight and the conditions. Some are high pressure, some are low pressure, some use the air pressure to adjust the sag/preload and use coils for the main spring.
    mtbtires.com
    Portland, OR
    Aug 2005
    Quote Originally Posted by shiggy
    hmm, well then. 05 kingpin. and you know the current conditions. all I know is that the stance fork is holding its own compared to my zocchi ....but i'm not sure how long that'll last.
    Ibex bikes
    2007 Ibex Trophy SS
    2006 Ibex Zone FR-1
    Glad to Be Alive
    I run mine at ZERO
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    Experiment, start with manufacture recomended then you know witch way to go .
    Bum Buzzer
    Reputation: Huck Banzai's Avatar
    May 2005
    Set it up the way it feels best to you - different people like their suspension setup diff!
    I like mine slightly on he firm side of plush.
    EXPERIMENT!
    Ideallly the fork should be plush and rideable at 0psi, and you add air to accomodate different conditions.
    Disco-Superfly
    Reputation: Jake_HT's Avatar
    Quote Originally Posted by SHIVER ME TIMBERS
    I run mine at ZERO
    me too, I dont have air assist
    Jake
    Yeti 303 WC 25th
    Quote Originally Posted by Dwight Moody
    Didn't you read the sticker on that shock? It said not to do whatever you did.
