How many people rock 823's or...........- Mtbr.com
Results 1 to 39 of 39
    Glad to Be Alive
    How many people rock 823's or run real UST rim tubeless and which rim you use for tubeless??
    ban
    ban is offline
    I do rock some ex823 with Michy tires...flawless in a year and a half...
    Jan 2003
    my 823's have been bombproof so far (almost two years)
    i drink shower water
    Reputation: hab1b's Avatar
    i use to run 823s tubeless with minions (non ust) and they were fine. However i had some incidents that turned me off of tubeless. now i run 721's with xc tubes.
    Prison is hard, everything else is easy
    I heart the drops
    Reputation: giantsaam's Avatar
    I run 823's on both my freeride and my xc bike and they are solid
    "its not how slack your head angle is, its how you ride the bike"
    Reputation: norbar's Avatar
    823 and Hutchinson Tires. I've destroyed some 729's and they seem to hold very good. I even run them at 15psi (by accident I didn't want to lower the pressure so much) and it's still very good.
    The only problem is putting ust tires on it. It's a real pain in the ass when the tire is even sligthly deformed and it requires too much work( or I'm doing sth wrong)
    www.totalbikes.pl - Bike Camps not only in Poland
    Aug 2005
    823 runing two years all ust tires w/o any problems, michelin 2.5 16 and 24, maxxis 2.5 dhf, continental diesel 2.5 and vertical 2.3, schwalbe fat albert 2.3
    ordered a second set for my dhr
    eci
    Reputation: snowskilz's Avatar
    823's for 3 yrs now. they are still running strong. i have had to replace more spokes then rims so far
    Its got what plants crave
    Reputation: Jim311's Avatar
    Feb 2006
    I run 819s on Hope Pro IIs. I don't go big, but tubes blow.
    Reputation: chup29's Avatar
    Nov 2006
    their pretty sick - mine are laced to dtswiss 440's and ive never had an issue - kept the spokes tensioned and never even had to have them trued
    Bottlerockin'
    Reputation: coiler8's Avatar
    DIdn't the 823s have an "off" year where there were some bad batches so to speak? What year was that? ... I'm ordering me up a set of 823/Hopes in a few days...
    Reputation: Irrenarzt's Avatar
    I have a set of 06 and 07 823's. No problems with either.
    EX823 with Dh 32 tires.....two years riding DH and still straight
    Reputation: Mikey_C's Avatar
    Mar 2005
    im all about avoiding mainstream on my builds(twist shifters, pink frames, etc) but after lots of research and debate I went with 823. the engineering and final product is way ahead of the pack. The weight scares many but when you take into account the durabliility(where a 5.1 is subject to catastrophic failure the 823 may just see a little bend) and the tubelss readiness make the 823 50 grams(at the most) heavier than the alternative.
    Why use anything else if going tubeless??
    823's laced to a DT 440 hub. Minion DHF's front and rear and no problems. No Tubes, just Stans
    Stray Bullet
    Reputation: Nagaredama's Avatar
    Anyone running their UST tires with Stan's?
    I'm new to 823's and have been running both Michelin's and Hutchinson's with no Stan's and haven't had a problem yet. Tires mounted right up with soapy water and a small compressor.
    Living Ghetto Fabulous!
    Reputation: Uncle Cliffy's Avatar
    3 years on 823's. There's no other.
    I've ran all the UST Maxxis and Michelin DH tires and right now I'm running some UST Nevegals in 2.35. I've put a hole in the rear one already, but a piece of innertube and some black CA glue and it's good as new.
    Quote Originally Posted by kidwoo
    The internet sounds like a tough place to ride.
    Big Test Icycles
    Reputation: Hangtime's Avatar
    819s on one bike and getting ready to build my 823s.
    Sep 2004
    823 + 2.5 ust minions + stan's tire sealant
    -C-
    -C- is offline
    Quote Originally Posted by hab1b
    Snap.
    Fed up with pinch flats where the sidewall touches the rim. Never really ran low pressures either. Rims stayed true though. Gave up, now back on 721's.
    Reputation: combatkimura's Avatar
    Quote Originally Posted by -C-
    Snap.
    What tires were you running?
    -C-
    -C- is offline
    High Rollers, Minions, both UST & Non, all dual ply ST.
    I don't know if it was the rim & the sort of tyre profile it created for my riding caused flats but it just doesn't work for me
    Trouble was the flats were so far up the sidewall the sealant can't get up to the holes.
    823 with michelin and maxxis. Two years now down the hill and zero problems.
    Jackalope Hunter
    Reputation: jayjudy13's Avatar
    823s laced to Saint hubs with Minnion 2.5 USTs, I've had the rims for about 4 years. No problems.
    "That which does not kill you makes you stronger"
    NO problems, though I did put a large tear in my rear UST Minion at Angel fire. About an inch long. I replaced it with a Michelin and had a decent race run.
    I'm running Syncros DS28s tubeless with stans and have had no problems. I've found Dual Ply UST tires have the least amount of problems with mounting, sealing, and have the best durability. I want to switch to 823s so that I don't have to deal with the strips and whatnot.
    sixsixtysix
    Guest
    I roll Eight Two Three's laced to Chris Kings with standard Maxxis Minion tires and a little bit of Stans. Great combination, no problems with burping etc.
    823's with hadley hubs and michey DH24, all gravy!
    Quote Originally Posted by bigmike00
    That's the exact setup I plan to run in the future. Already have the Hadley's, looking for a swingin deal on the 823s. As soon as I find one they're gettin laced up.
    Stray Bullet
    Do you cut the intermediate knob on you DH24s? What kind of dirt do ride in?
    I heart the drops
    Quote Originally Posted by combatkimura
    Give the boys at rocky mountain cyclery a call they do pretty well
    http://www.rockymountaincyclery.com/
    I HUCK WITH CHUCK
    Reputation: ThoughtfulPirate's Avatar
    Jan 2003
    823s on Industry Nines here. Been running them for about a year and haven't done more than tensioned a spoke or two. For the most part ust has been fine with michelins, but I do have a habit of ripping holes in tires on jagged, rocky tracks.
    Glad to Be Alive
    same here for 5 years...... sometimes michy 32"s in the front
    from 0 - sideways 3.2 sec
    Reputation: derekr's Avatar
    I run 823's and minion UST's, been on the bike now for over 9 months with NO problems what so ever!! I run @ 20 - 25 psi.
    i'm on the 2nd season with my 823's i ran them with UST Minions and never ever had an issue, i now am selling my fully so put them onto my hardtail with some 2.35 nevegals *non ust* i added a bit of stans sealant to be safe and once again not a problem.
    Reputation: Mr. Blonde's Avatar
    823s on Pro 2s here.
    Reputation: tatankainlondon's Avatar
    823s on turquoise powdercoated DT440s and Michelin DH16/24 tyres.
    2 wheel drifter
    Reputation: blackbart's Avatar
    823's on a 440 rear and a marzocchi front hub with maxxis minion tubeless. There are few hops and replaced a couple of bent spokes after 3 years but they still work great. I've been running them with alloy nipples with no problems.
    Reputation: MBX5's Avatar
    DeeMax and 823's for me with Stans and UST Maxxis have also run Kendas non UST
