How to make tires round again??- Mtbr.com
Results 1 to 8 of 8
    StraightOuttaCompton
    Reputation: Djponee's Avatar
    Hey, I jut got some new tires off of the internet, and as you know, they like to shove big things in little boxes. The tires got all warped and out of shape because of this. How can i fix the tires so they are round/flat/regular again??
    HARDTAIL PRIDE- 09 Kona Five-0
    General Rabble-Rouser
    Reputation: Karupshun's Avatar
    Mount it on a rim and it should be fine
    did they seriously kind the wire bead?
    no, the beads are straight, but the tread is crooked and the sidewalls are bent in a little bit.
    Quote Originally Posted by Djponee
    Just inflate it, and it will be juuuuust fine
    ok, that is what i thought but i wanted to make sure before i put them on.
    Pivotal figure
    Reputation: kenbentit's Avatar
    Jan 2003
    Hopefully you didn't get a reject tire. Sometimes we see tires where the tread isn't straight due to some problem in manufacture.. If that's the case you're basically stuck with it.
    Desert Sunset Calls/Upward, Pain, Perseverance/Welcome Solitude
    no, if you mean the tire is unproportional, they aren't, i am pretty sure that it is from them being stuffed in a 12X10 box.
    Meh.
    Reputation: XSL_WiLL's Avatar
    As long as the bead isn't kinked, just mount it and pump it up. They twist them to fit in smaller boxes and save on shipping.
