How to make the 09 Saint 4pot brakes not feel like turd- Mtbr.com
Results 1 to 13 of 13
    Reputation: Nick_M2R's Avatar
    X post from brake forum
    Hi all
    Recently i just bought my mates 08 kona Bass off him
    He also gave me a rear shimano saint brake, the new 4 pot one
    Took em for their first ride and holy crap, they feel like effing turd
    Modulation is non exsistant, you pull the lever in and its like nothing...nothing...nothing..not..BRAKE LOCK! , honestly my old HFX had better modulation and control than these do
    The lever also has a very spongy feel, but i reckon a bleed will fix this, but will a bleed also fix the SHOCKING modulation that my unit has? Im pretty sure the brakes are better than this, and i want to get them working nicely
    Also what does the freestroke adjust do? Is it like the avid pad contact adjust?
    Looking forward to any help, as i really wanna get these brakes working properly, there is def no shortage of stopping power, but ive got almost no control over it...
    Cheers
    I might go down a rotor size to fix this issue. my levers are rock solid, so I think you're right about the bleed.
    I also haven't broken in my pads properly, so we'll see what happens after another weekend of riding.
    *2009 Canfield F1 Jedi
    *2008 Superco Charger
    *2008 Giant ReignX-0
    err, 27.5+
    Reputation: AL29er's Avatar
    Interesting. MTB198 also mentioned turd-like behavior out of his Saint brakes. Wonder what is up. Most are gushing about the power and modulation, but there are obviously a few bad apples floating around
    MTB198 review
    Quote Originally Posted by saturnine
    that's the stupidest idea this side of pinkbike.
    UNDEAD
    Reputation: snow-man's Avatar
    Mine are amazing
    Set up front and back with 8inch rotors, adjustment and modulation is perfect.
    All I did was bleed them before installing. I flicked the cables while the mineral oil cap was open for at least 10 minutes each, got a TON of bubbles out of the cables.
    no problems....
    I'd reccomend doing the same. Any brakes out of a box/shipping should not be expected to run perfect.
    Show 'em some love and they will return the favor...
    Good luck
    slow reeezay
    Reputation: hecticj's Avatar
    ditto that mine have been amazing since day1 with 8" rotors loads of power and modulation.........................
    Maybe bleed it and check the pads out, the last guy that owned them may have contaminated them?
    LIVE TO RIDE, RIDE TO LIVE
    2011 On-One 456 Ti
    2010 Trek Session 88 custom build
    Mine also have excellent modulation and power (running front only on my downhill bike and my uphill bike). As snow-man said I got a ton of tiny bubbles out by tapping the hose while pumping the brake with the top cap off. Also make sure you fill the reservoir with oil before putting the cap back on. I always set the free stroke adjustment to the minimum (full clockwise). And yes, you can get really bad modulation when you have air in the lines.
    bikeaholic
    A bleed will definitely fix the spongy feel. I work in a shop where all of the rentals are equipped with Saints and the "no modulation" is common feedback. I took my buddy's bike for a run, with Saints, and I agree that they take a little getting used to. It's just that those brakes have TONS of stopping power and they require a very precise feel. In my opinion, you just have to teach yourself to be very precise with them.
    I will say this about your set up though, I wouldn't have a Saint ONLY for a rear brake. It's tough to teach your left and right hands to modulate differently. If anything I would have the more powerful set for the front. Just my .02.
    squish is good
    Reputation: Clutchman83's Avatar
    Quote Originally Posted by Nick_M2R
    FWIW I test rode a bike with them and my experience was identical to yours. Typical fixes are run one resin pad, one metallic or smaller rotor.
    Bike good, work bad.
    Reputation: 006_007's Avatar
    Sell em and get a set of Maguras.
    long standing member
    Reputation: PCinSC's Avatar
    Quote Originally Posted by 006_007
    Specifically...Gustavs.
    These brakes have zero modulation when you're dicking around in the streets at low speed. They just give you whiplash. But once you get up to speed they modulate really well.
    Thanks for the replys guys, i will def try giving these brakes a bleed and hopefully it will fix the problem, i know they are better than this because my mate who i bought the Bass off has another set of saints on his NS, and they feel A HELL of alot better than mine do
    Now with More Wood
    Reputation: Iceman2058's Avatar
    I have posted before about the near-death experience I had when I jumped on my friend's Saint-equipped bike (a Demo...and since then I have re-verified my "findings" on a Remedy)....all that power just suddenly applies with very very little modulation. It was on a lose and steep section of the trail and I had all sorts of trouble trying to control the bike. Codes have way more modulation and feel (and to think people used to complain about them!). I have no doubt you can get used to the Saints, but enough people share this opinion on the on/off nature of the new Saints that it warrants being discussed, at least...
    Maybe try softer pads for the Saints, if they ship with metallic out of the box or whatever?
