How to Adjust Hydraulic Brakes- Mtbr.com
Results 1 to 12 of 12
    hi, kind of a beginner question, but i got my bike back from the bike shop after replacing the pads, and i notice the front brake it rubbing. how can i adjust the brakes so they are not rubbing? do i have to bleed the brakes and all that? or can i just do a simple screw adjustment?
    thanks.
    C S
    C S is offline
    Reputation: C S's Avatar
    It sounds like your brake calipers need to be aligned. This procedure MAY vary between different manufacturers, I can't say for sure. I align my Juicy 5s by loosening the screws that attach the caliper to the fork or frame, squeezing the lever a few times, and then holding the lever in and tightening the screws at the same time. It sometimes takes a few tries to get right, but it works for me.
    Reputation: LarryFahn's Avatar
    If it's a DH bike, just do a run or two and it'll stop. Don't re-bleed. Fahn
    Hubbard Bike Club
    Reputation: CA_Descender's Avatar
    Depends on the rubbing, there tends to be some drag with new pads so just go and hit a few long descents. If it is actually pressing on the rotor and the wheel does not spin well then ya might need to adjust them or take the bike back to the shop, have them adjust as they should have and watch how they do it.
    Disco-Superfly
    Reputation: Jake_HT's Avatar
    What brakes are they? You can take the brake pads out and push the pistons back in with the open end of a wrench... If you pushed them too far just give the lever a few squeezes and they'll come back out again..
    Jake
    Yeti 303 WC 25th
    Quote Originally Posted by Dwight Moody
    Didn't you read the sticker on that shock? It said not to do whatever you did.
    ignore this
    Reputation: boogenman's Avatar
    6 steps to fix your problem:
    1. Take your wheel off.
    2. Use plastic pad spacer that came with the bike/brakes and wedge it in the caliper to push pads all the way back.
    3. Put wheel back on the bike. DO NOT TOUCH BRAKE LEVER.
    4. Loosen the caliper from the adapter/post mounts.
    5. Spin the wheel to make sure it is moving freely, squeeze the brake lever and hold tight.
    6. Tighten caliper.
    Glad to Be Alive
    Quote Originally Posted by boogenman
    6. Tighten caliper.
    re-align them up after you hit brakes too
    i don't have that spacer... what should i use?
    Quote Originally Posted by Kiran M
    What kind of brakes are on your bike?
    look here and choose a brake type, i.e. hays, avid, etc.
    http://www.parktool.com/repair/byreg...mageField2.y=9
    i have hayes brakes on the bike.
    should know better.....
    Reputation: neverwalk's Avatar
    May 2005
    You can use a flat head screw driver blade, the wider, the better.
    Just be gentle as you 'pry" the pads apart/compress the pistons, you should not see any flaking or chipping of the pads from whatever tool you use.
    Then do as the others have said, insert the wheel, loosen the caliper mounting bolts and wiggle it with your hand so it is truly free to move, then squeeze the brake lever firmly, keep it squeezed as you tighten the mounting bolts. release it after wards, give the wheel a spin if it rubs, try again. It should work.
