Help with my stupid hub!- Mtbr.com
Results 1 to 21 of 21
    Upset Help with my stupid hub!
    I have a Sunrace Juju DH hub with the 20mm axle and i cannot get the axle out and i have tried everything! If you know how to do this can you tell me cause im gettin pissed cause a MTB Park is opening near me soon and i need my new fork instaled.
    Pro Crastinator
    Reputation: .WestCoastHucker.'s Avatar
    axle slides in, axle slides out. if it's stuck, smack it harder...
    Glad to Be Alive
    take is to your LBS
    Disco-Superfly
    Reputation: Jake_HT's Avatar
    are you using a marzocchi axle? take off the QR mechanism.......
    Jake
    Yeti 303 WC 25th
    Quote Originally Posted by Dwight Moody
    Didn't you read the sticker on that shock? It said not to do whatever you did.
    It was the axle i used for my DJ 2 but i dont see any QR thing. Whats it look like?
    Reputation: free rider's Avatar
    uhh, use a cone wrench and take the cones off (i dont know if im talking obout the same thing here)
    Pro Crastinator
    dude, you put the axle in the hub and now your can't figure out how it comes out? here is a hint, go in the reverse order that you use while putting it together....
    ...for I am a raindog too
    Reputation: RaindogT's Avatar
    are you lookin
    to get the thru axle out of the fork drop outs? Or get the axle (20 mm axle) out of the hub? We might be able to help with more info.
    Pro Crastinator
    rule of thumb, if the front wheel is smarter than you, you don't belong anywhere near a bike....
    I need to get the axle out of the hub....and i didnt instal it, i bought the bike and it had the axle in the hub and on the fork. How hard would i have to hit it if it was stuck, cause i have beaten the sh** out of it and i got nothin!
    Pro Crastinator
    so, you can't even get the wheel off the fork?
    Quote Originally Posted by LoudonHucker324
    it sounds like you havent taken the cones off....something is holding it back, clean all the grease off and take a look what is stopping it, you may need to take both sides off and try from the other side
    Disco-Superfly
    I take it this is not a sealed cartridge bearing hub...... I will shutup
    Jake
    Yeti 303 WC 25th
    Never mind.... got it!
    Pro Crastinator
    i'm curious, what was the deal?
    Salsa Shark
    Reputation: bedheadben's Avatar
    Ya, what did you do?
    "Man goes in the cage. Cage goes in the salsa. Shark's in the salsa - our shark! We're gonna need a bigger boat."
    Quote Originally Posted by bedheadben
    WHATEVER IT WAS, IT DIDNT INVLOVE CHANGING YOUR SIGNATURE...ALTHOUGH IT SHOULD HAVE
    Pro Crastinator
    just turn the sigs off if you're that offended. you whiny little baby.....
    Premium Member
    Reputation: Ojai Bicyclist's Avatar
    Quote Originally Posted by free rider
    You're an idiot. He's talking about a thru-axle, not an axle as in the internals of a hub.
    Meh.
    Reputation: XSL_WiLL's Avatar
    He probably didn't loosen the pinch bolts before trying to remove the axle.
