Headset help...?- Mtbr.com
Results 1 to 19 of 19
    Authority is dead!
    Reputation: Lucky13's Avatar
    Headset help...?
    What is the best short headset out there?
    Can I use integrated headset on the regular frame? Are they as good as non integrated?
    For the love of Oi
    Rent a house at Attitash
    Pro Crastinator
    Reputation: .WestCoastHucker.'s Avatar
    your frame has to be pre-designed to accept an integrated headset, you can't just throw one on any old bike.....
    and usually a frame designed for one style, dosen't accept the other design....
    Authority is dead!
    Ok, what is the smallest headset out there then?
    For the love of Oi
    Pro Crastinator
    probably something from cane creek. why the need for such a short stack?
    Authority is dead!
    Found my ideal fork but has somewhat short steerer,but don't want to bother with re-pressing it.
    For the love of Oi
    Pro Crastinator
    you can also try looking for a stem with a shorter stack......
    Authority is dead!
    I'm looking at both actually.
    For the love of Oi
    Pro Crastinator
    cool, most people will usually overlook one or the other...
    Authority is dead!
    What would be a good short (50mm) stem with low height?
    For the love of Oi
    Pro Crastinator
    the KORE B1B is pretty short and even comes in a 35mm.
    but it isn't for a 31.8mm bar if you need that...
    Chillin the Most
    shortest "durable" headset
    would be the Aheadset Tank, stack height is @ 1" if memory serves me. Cromoly cups. Trust me I went through all this when I was trying to fit the Shiver on my Big Hit.
    Authority is dead!
    One that comes with Bighit? No way, never ****ing again! It started failing after 10 minutes of riding.
    For the love of Oi
    Chillin the Most
    well
    Quote Originally Posted by Lucky13
    the your sh!t outta luck, because thats the shortest strong headset out there. Weird you had problems with yours I've been using one for months now and not an issue. Perhaps you torqued the headset cap to tight, causing premature failure. What happened to yours?
    Trials Superstar
    Reputation: RigidOne's Avatar
    Quote Originally Posted by .WestCoastHucker.
    yeah i had problems fitting that B1-B stem because the stack height was so small! it is a very nice stem, $26 at www.airbomb.com
    Please purchase products from JensonUSA your #1 Internet Dealer for MTB parts!
    AS SEEN ON THE X-GAMES and GRAVITY GAMES! How would you like to go 80 MPH on a bike 4 inches from the ground? Well you can learn how at GravityBike.com the home for BMX Speed Machines!
    2004-2005 Sponsors
    Maxxis Tires
    Targert Sponsor
    Azonic
    Hayes
    Authority is dead!
    Quote Originally Posted by red5
    I got my Jr.T on, and it started losing itself up after 10 mins. I'm very careful with stuff like headsets and I doubt that it was my fault. I was loosing it self up even with stock DJ2.
    For the love of Oi
    Chillin the Most
    sounds like...
    you need an Azonic headlock, starnuts s@ck and I would never trust them. maybe that's why mine has never had a problem. I wouldn't blame the headset for the looseinig though, sounds like faulty setup somehow. Oh well, since your options are limited it should be intersting, good luck.
    Isnt the shortest headset out there the new Evil Zero Stack???
    Chillin the Most
    Quote Originally Posted by BostonBull
    the only E13 Zero Stack that I'm aware of is the reducer cups for 1.5 headtubes. check it...E13 1.5 zero-stack reducer cups
    Aheadset does make a headset with a stack height of @ 22mm, but I wouldn't use it for DH/FR riding like Lucky is doing.
    Authority is dead!
    Yeah, after that I got FSA Pig and the Headlock; set and forget!
    For the love of Oi
  1. Replies: 4
    Last Post: 10-04-2004, 05:46 AM
  2. headset stack height and head tube length
    By Earthpig in forum Tooltime
    Last Post: 08-20-2004, 02:13 PM
  3. Replies: 4
    Last Post: 07-11-2004, 04:11 PM
  4. Opinions on greasing headset cups
    By Lab Worker in forum Tooltime
    Last Post: 06-14-2004, 07:28 PM
  5. How to change an intergrated headset for a regular?
    By BanzaiRider in forum General Discussion
    Last Post: 05-19-2004, 10:06 PM
