Head Angle a Little to slack (pic)- Mtbr.com
Results 1 to 8 of 8
    Sep 2004
    So i was crusing around pinkbike and a found this in the classfides
    You couldn't pay me to ride that, it just looks dangerous...
    Reputation: misctwo's Avatar
    Quote Originally Posted by RuNDmC1087
    ovaltine city
    The 24" rear wheel is a bit puzzling, but I've seen similar setups with 26" wheels on the older Bullits (the ones you weren't even supposed to use a DC fork on), and it was fine. I used to ride with 2 guys that slapped Shivers on, and it seemed to suit them well.
    This setup does look pretty raked though.
    Xtremely Moderate
    Reputation: e<i>o's Avatar
    Quote Originally Posted by Shibby
    It needs a seatbelt.
    "Korash your enemiez, zee zem driven bevore you, and ear ze lamentation of za vemen"
    Glad to Be Alive
    Shiver ahoy !!! Many guys in San Diego sport the Shiver on Bullits. But I never seen it with a 24 inch wheeel
    hands up who wants to die
    Reputation: rpet's Avatar
    I haven't been to pinkbike in a while, but those forums used to be all about hucking off mommy and daddy's garage to flat, and this set-up for the Bullitt is probably pretty good for doing that.
    -rpet
    That 24" rear wheel isn't helping things either.
    rollin
    Reputation: sriracha's Avatar
    adjustable angles
    couple of my bro's used to ride bullit's with shivers. bullits rule. never seen one with a 24" wheel though, it probably slackens things a degree or two. the bullit has an adjustable head tube angle. check those two bolts in front of the rear shock. there's a slotted shock attachement. you can loosen the two bolts and slide the shock attachement back, lifting the bottom bracket and steepening the angles.
  1. Fork rake/trail/head angle experiments
    By Walt in forum 29er Bikes
    Last Post: 10-23-2015, 05:33 AM
  2. Stumpy FSR 120 head angle question...
    By riverrat in forum Specialized
    Last Post: 09-19-2005, 05:50 AM
  3. balance of rear travel vs head angle vs bb vs ?
    By FoShizzle in forum Ventana
    Last Post: 10-20-2004, 12:37 PM
  4. Bullit head angle
    By Dirtdemon in forum Downhill - Freeride
    Last Post: 03-05-2004, 10:43 PM
  5. Freeride poll
    By R_D in forum Downhill - Freeride
    Last Post: 02-25-2004, 04:01 PM
