Hadley Hub Service Guide By Go-Ride.com- Mtbr.com
Results 1 to 13 of 13
    Reputation: krispy@go-ride.com's Avatar
    Hey fellas,
    I have put together a service guide for rebuilding Hadley rear hubs.
    This is meant to be a routine maintenence reference for the average rider. If your hub is fully seized and you're not experienced in pressing out bearings you probably will want a good tech to do it for you. For this reason removal of the cartridge bearings is not included.
    However, cleaning the pawls and needle bearings along with inspection of the seals should be done regularly and is quite simple.
    Krispy
    https://www.go-ride.com/hadley_hub_r...ance_intro.htm
    Santa Cruz Bronson 2 27.5/Rockshox Pike/Sram XX1
    Salsa Mukluk/Rockshox Bluto/Sram X1
    Glad to Be Alive
    a tight kick sound
    Reputation: boone's Avatar
    That's awesome thanks!!!!!!!!!
    Booner
    That is some good stuff Krispy!!
    But does Go-Ride stock bearings and seals for Hadley's?
    edit:
    "Hadley is hard to get ahold of so we (Go-Ride) stock all the service parts here. Hadley gives us bags of pawl kits and seals whenever we need them. Give me a ring if you need parts."
    I just saw this in another post. Keep up the good work guy's!
    Disco-Superfly
    Reputation: Jake_HT's Avatar
    wow...
    so in about 50 years when my hadley starts to un freshen.........
    Jake
    Yeti 303 WC 25th
    Quote Originally Posted by Dwight Moody
    Didn't you read the sticker on that shock? It said not to do whatever you did.
    East Coast Style
    Reputation: acdcfan1283's Avatar
    Quote Originally Posted by [email protected]
    wow...
    mine went after 3 months, dont doubt anything...
    Thanks Kris for the setup guide, greatly appreciated. props
    would also like to ask, is it one spring or two? cuz in the pics it looks like one, but mine its two.
    Intense Socom
    Transition Double
    [/SIZE][/FONT]
    It should only be 1 spring! Maybe that's why you're having problems!
    East Coast Style
    Thatd explain everything! Alright at least I know now.
    Intense Socom
    Transition Double
    [/SIZE][/FONT]
    I like air!
    Reputation: milhouse's Avatar
    Thats cool, now I know where to look when it comes time to service my Hadley. Thanks!
    Reputation: Allamuchy Joe's Avatar
    Thank you for putting this information the this site. It has been a great help.
    I have a question regarding Hadley hubs. My girlfriend’s Hadley hub has been sticking intermittently (the chain jerks forward, and then the hub slips like it should, then it sticks again, etc). I took the freehub off, cleaned out he debris inside (which consisted of some small metal chips), cleaned the pawls and put it back together. I used bike grease as my lube for the hub.
    Well, the hub still has the same issue. When the wheel is spun on the bike without load, the freehub ratchets freely. But when coasting with a rider's weight on the wheel, the same sticking behavior is observed. Any idea of what the problem might be?
    Thanks.
    I figured it out. The two radial bearings were worn out -- the had too much radial play which allow the whole axle assembly to cock and bind up a little bit.
    My LBS is ordering the bearings and is going to press them in for me.
    Reputation: 1000-oaks's Avatar
    Nov 2006
    Hey thanks Krispy, I've been meaning to tear mine apart for months. (the pedals turn when you push the bike, must be drag in the freehub)
    Craig Kelly is my copilot.Product Marketing and Product Photographer
    Reputation: xKREDx's Avatar
    cool.........ive been thinking about getting one of those hubs for my new build
    Quote Originally Posted by shredder111
    Can I paint your rockring, silly bun salad?
