Goggles or no goggles- Mtbr.com
    Jun 2016
    Hey,
    I don't tend to get along with goggles so much for the following reasons.
    Any ideas how to get around these issues, I don't wear them as a result but think I probably should.. I'm using Oakley Crowbars with a standard clear lens
    1) After a short while I simply get too hot! Without get the ventilation on my face I overheat
    2) I steam up the moment I stop riding and remove them, then putting them back on I have moisture all over the inside of the lens
    Should I get better lenses? Should I get a better 'ventilated' goggle?
    Reputation: LarryFahn's Avatar
    You can fix both problems very easily. Look at the top of the goggles and in between the foam that rest on your face and the lens holder, there will be some more foam. Take a knife and cut that foam out. There will be plastic underneath the foam with holes in it. By removing the foam your goggles and your face will have circulation. Also remove the foam on the bottom. They're small holes in the frame that keep junk out. 3 of us had problems this year @Whistler where the temps would change 30* throughout the day. The goggles looked like a windshield during a downpour. We removed the foam and problem solved. Even in the dust @Creek this year I had zero problems.
    Ttyl, Fahn
    Hubbard Bike Club
    May The Force Be With You
    Reputation: shwinn8's Avatar
    Feb 2006
    Goggle's keep my eyes from watering at high speed does good for keeping mud and dust out too
    '01 Straight 8
    '16 Balance
    '11 Jedi (for sale, small)
    Jun 2016
    Quote Originally Posted by LarryFahn View Post
    Ttyl, Fahn
    Thanks Bud, will do!
  1. What goggles?
    By [email protected] in forum Downhill - Freeride
    Last Post: 03-13-2012, 03:41 AM
  2. Have you seen my goggles?
    By DDDonny in forum Nevada
    Last Post: 02-05-2012, 01:13 PM
  3. snowboard goggles, MX goggles...whats the difference?
    By musky in forum General Discussion
    Last Post: 10-12-2011, 10:22 AM
  4. Goggles
    By SUITEDFINGERS in forum Downhill - Freeride
    Last Post: 10-07-2011, 04:51 PM
  5. LBS with goggles
    By induction in forum Arizona
    Last Post: 07-07-2011, 09:58 AM
