Glory owners with saint cranks- Mtbr.com
Results 1 to 5 of 5
    yaha ha
    Reputation: snowforner15's Avatar
    I bought some used cranks for my 06 glory.
    How many BB cup spacers do i use and which side?
    how much were your cranks
    Reputation: ScBullitFr3rider's Avatar
    Quote Originally Posted by snowforner15
    maybe one or two on the drive side to get the desired chainline, you're gonna have to take it on and off and experiment with # of spacers seeing as you probaly dont have a manual since they're used. 3 spacers might be too much because your spindle is only so long and it might not be long enough for you to thread the endcap on the non-drive side. You might also have to play with the spacing of your chainguide if you run into alignment problems.
    Good Luck, it can be a pain, but they're really nice cranks, easiest to setup out of the External BB bunch.
    Meh.
    Reputation: XSL_WiLL's Avatar
    You did get the 83mm model, right?
    Instructions should be on the Shimano website.
    yaha ha
    ya made sure of 83mm
    and to answer the question they were $$160 used once..
