Giant Glory & DHX Air?- Mtbr.com
Results 1 to 9 of 9
    Hi Guys,
    I want to know if it's commendable to put a DHX Air (5.0) into the Glory. At the moment a DHX 4.0 Coil is installed, but I would save about 650g by riding the DHX Air. (with another modification: 18,8kg -> 18,0kg)
    Unfortunately I've only seen coil-shocks in the Glory. So... does the Air fit? (-> too high gear ratio? Forces on the shock?) I can't remember it clearly, but I think I've seen a Glory with the DHX Air already.
    Can anybody help me with that problem? Dont want to spend money on sth. which won't work.
    Attached some pics of my Glory...
    Greetings from Germany
    Ricardo
    Glad to Be Alive
    you can get an air shock but you will lose the plushness of the coil
    If you are doing more XC rides or using it RACE ONLY then I would get the air
    if you are doing drops, jumps and such you will beat up the air shock fast
    Quote Originally Posted by SHIVER ME TIMBERS
    RACE ONLY
    got it
    notabouttoseeyourlight
    Reputation: coma13's Avatar
    throw on a Ti spring...
    cycle tracks will abound in utopia.
    for what? Spending 200$ for saving 80g of weight? (rcs ti spring to the normal fox spring)
    Quote Originally Posted by richy_a2r
    how heavy of a spring are you running?
    -> SickLines.com <-
    Reputation: mtb_biker's Avatar
    That depends on how big your spring is. I'm pretty sure the springs on the Glory's are bigger and i'd expect closer to at least 1/2 lb. TI springs have better tolerances than steel ones so a 400lb steel spring could be 380lb or 450lb. etc
    500x3,25
    but i'd prefer a 450...
    air:
    1g = 16 ct. = 0,16€ (640g to save)
    ti spring:
    1g = 2€ (~100g to save)
    next thing to change would be crank/bb... middleburn rs7 -> again ~450g... sometime.
    Me hates pinchflat
    Reputation: 545cu4ch's Avatar
    Aug 2005
    your glory is hella sexy
    Quote Originally Posted by sriracha
    "jesus would huck it"
    Quote Originally Posted by FoShizzle
    i have found the 1.5" headtubes to be slightly larger in diameter than 1 1/8", plus or minus
