gemini difference?- Mtbr.com
Results 1 to 13 of 13
    e.f.f.e.c.t smoothoperatr
    Reputation: themarsvolta55's Avatar
    Dec 2004
    gemini difference?
    hey... simple question im looking in to getting a gemini and i found a 2003 gemini but its yellow... and when i go onto the cannondale site, there is no yellow gemini
    whats the difference between these?
    http://bike4fun.150m.com/
    http://cannondale.com/bikes/03/cusa/model-3VG9.html
    Sep 2004
    If you look down on the color options of your second link it lists Taxi Yellow as one of the color options so it is the same bike. I just picked up an 05 Gemini 3000 in Mocha/Saffron. It is an awesome bike. You might want to make sure the one your looking at isn't the year that had the frame issues, but I think it was an earlier year.
    Dec 2004
    Quote Originally Posted by Oldhippie
    well uh oh..... i hope its not the 03's how can i find out which year is the one with the frame probs... and what kind of probs were they?
    Reputation: Gemini's Avatar
    The early frames of 2002 had some probs with the downtube. But that had been solved . You can look at the cannondale site by racalls and you'll find an answer. The probs only appeared at frames with the lage sizing !
    Sep 2004
    I'm sure someone on this board knows. Check which year CDale started making Gemini's as I think the problem was resolved after the first year. Cdale had a recall and has significanlty beefed up the Gemini and particularly the rear swing arm since the first few years. I haven't heard of any problems at all since those early ones. After a quick search, I found Gemini's as far back as 2000 and I think they started making them in 99 or earlier so I think you are definitely safe with an 03. By the way, I love the bike so far and the 2000 I demo-ed several times last summer. I was basically a CDale and Gemini hater based on the stereotypes and brand loyalty to Kona and Specialized. One ride on a 2000 completely changed my opinion.
    Jan 2005
    the 2003 frame did have the recall for the mistake on the downtube and i own one and i will tell you it its a goob bike and i just love the fork but i would either have the fox pushed or get a 5th element
    Dec 2004
    2003 Gemini 900 ( the one i want to purchase?????)
    The nature of the problem is insufficient wall thickness in a critical section of the downtube of some medium and large Gemini frames due to a manufacturing error. This was caused by incorrect mitering of the down tubes of these frames resulting in the removal of too much of the thickest, or "butted", portion of the downtube during manufacture. Removing a large portion of this butted tubing leaves only thinner aluminum tubing at the headtube joint; weakening the frame in the area where the downtube and headtube are welded. This results in insufficient frame strength in this area and the risk of frame failure.
    OH COMEON!!!
    /dev/null
    Reputation: binary visions's Avatar
    Quote Originally Posted by themarsvolta55
    OH COMEON!!!
    What's the problem here? Just find a shop with a Cannondale rep, or send it to Cannondale and have it checked. If it's got the problem, it'll get replaced. If it doesn't, then you're fine.
    Dec 2004
    Quote Originally Posted by binary visions
    i might be getting mixed up... the downtube is the part of the bike that says cannondale? how can i get that replaced? im not buying it brand new, im getting it from someone on ebay
    /dev/null
    They don't replace the downtube, they replace the whole front triangle.
    As far as buying it on eBay goes... I'm not sure - I don't know if the manufacturer considers a recall to be a "warrenty" situation that doesn't apply to used frames, or if they'll help you out. Might want to email Cannondale.
    Dec 2004
    so oviuosly the metal is to thin and brittle that it just breaks when your hucking? im gunnu email cannondale and see about the warrenty thing
    Or let the guy who wants to sell it check it by his local Cannondale Dealer. It's not a big deal !
    Dec 2004
    Quote Originally Posted by Gemini
    well i dont want my freakin rig to crack in half.... has anyone had this xperience?
  1. 05 rig- gemini DH vs. Demo 8 Pro?(single pivot vs FSR)
    By biker3 in forum Downhill - Freeride
    Last Post: 12-15-2004, 11:32 AM
  2. Do 29ers cure cancer?
    By Ptor in forum 29er Bikes
    Last Post: 10-07-2004, 04:18 PM
  3. Gemini sizing and Romic question.
    By ronny in forum Cannondale
    Last Post: 09-15-2004, 12:14 PM
  4. granny ring/mid ring size difference
    By ryanc44 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-14-2004, 12:47 PM
  5. Can't Decide on Gemini or Uzzi SLX
    By MoeChedda in forum General Discussion
    Last Post: 08-26-2004, 08:35 PM
