FSA The Pig reducer headset keeps coming loose..- Mtbr.com
Results 1 to 14 of 14
    It's carbon dontcha know.
    Reputation: 6thElement's Avatar
    I'm running an 07 RC2X Marz 66 on my Highline with an FSA Pig Reducer headset. Every so often I'm having to stop and re-adjust the headset because it comes loose and I can feel play. The stem is always tight so I'm not sure how I'm developing the play.
    Has anyone else run into similar issues with reducer headsets?
    should know better.....
    Reputation: neverwalk's Avatar
    May 2005
    Did the lower race get seated properly on the fork crown? Because if you tighten the star nut/top cap down snug, then tighten the stem correctly, that's the only other thing that can move to create the loose headset. Make sure it is bottomed out, and that when you put it all together, everything is being assembled in the right order, and seating properly.
    Yeah I know. If I could get the damn fork out of the headset I'd start again from scratch. But I'm hitting it as hard as I can with a rubber mallet and the compression cone thingy in the top doesn't want to budge to free the fork :/
    Professional Troll
    Reputation: Gemini2k05's Avatar
    Apr 2005
    the star nut must be coming loose then, try a headlock. Or replace the bearings.
    Fork off, POS headset inspected...
    I'm using a compression plug, but that shouldn't even be a consideration once the stem is tight...
    Meh.
    Reputation: XSL_WiLL's Avatar
    Just because the stem is tight doesn't mean that it isn't slipping. Had a Thomson stem and a CK headset of a road bike... never stopped slipping. Switched to some housebrand stem and no issues.
    Professional Troll
    Apr 2005
    Quote Originally Posted by 6thElement
    Ya its a **** headset. I just pulled mine apart to replace a fork, and I had sheered off a section of the bottom cup. Like a circular chunk of aluminum (or steel) just fell out. Cane creek now, FTW.
    moaaar shimz
    Reputation: tacubaya's Avatar
    The Pig DH Pro is much better.
    Meh.
    The sheering sounds more like improper installation... A member on MTBR had completely sheered off the upper cup of his Sunline headset.
    While the Pig DH Pro may not be the best headset out there, it does the job just fine.
    Professional Troll
    Apr 2005
    Doubtful, I've a pretty competent mechanic I'd like to think (years of working in a shop and wrenching on my FR/DH bikes, but I'm not above making mistakes I suppose). Maybe I ****ed up, but the headset cups themselves were a factory install, so maybe I could blame it on cannondale......I sure would like to divert the blame away from my incompetence if possible.It was just a chunck from like the area contacting the bearings, not like the surface that's against the headtube. Which made me believe that I had probably tightened the compression nut too much and just crushed the whole assembly. But the bearings were in fine shape, probably could've reused them. oh well, whatevs
    Meh.
    Was the frame faced and reamed to the correct specs? And deburred? It doesn't happen on a number of mass produced bikes... cost cutting... Great.
    The crown race is fully seated on the steerer, the cups are fine, I changed from a Thomson stem to a Deity to see if that helped before this past weekend, but I was still getting the issue.
    Now that I've taken it apart and put it all back together, I'll go find some stairs to jump off later and see how it fares.
    get rid of the compression plug. I tried a step better the hope head doctor, it kept coming loose, put back in the a good ol star nut and never has come loose again.
    Quote Originally Posted by chinkerjuarez
    Thanks for that info.
    Thanks for the thread too, OP. I have a Fat Pig reducer headset coming in this week for my Bottlerocket. I'll definitely keep an eye out for this issue.
    But I won't be using this headset forever. Once I get a 1.5" steer tube fork, I'll probably get a Chris King or Cane Creek headset.
    Jump it onto something off of something or over something.
    There's more to freeriding than dirt jumps.
